Question about Dell A920 InkJet Printer
Printer acts like it's working then produces a blank page
My printer abruptly quit working several months ago in the middle of a print job. now whenever i try to print or scan something, the printer acts completely normal but produces a blank page each time. i uninstalled and then reinstalled the software but no change. any help??? do i just need to take it to the dell store?
  • 1 more comment
  • Lauren Langley Aug 01, 2007
    yep, good cartridges with half-full ink at least. and it prints blank whenever i print a test page.
    yes, i tried cleaning both cartridges several times. however, my brother hooked the printer to his computer recently and was able to print. so i'm not sure what the problem could be with my computer. i have a dell inspiron notebook.
    okay, first i tried a different usb port with no luck. when i pull up the driver and try to remove it, it says cannot remove driver, printer is in use although the printer is not connected. how do i get rid of this message? i really really appreciate your help!!
I had the same problem with my cartridge. I soaked it in hot water for a minute or two three times. It started to print but then soon became blank again. I then soaked it for 5- 10 minutes again in hot water, dabbed it dry on paper towel and it works likes a charm!
Posted on Jul 13, 2008
  • 98 Answers
Try to print first a self test page on the printer. Does it print a blank page also ? Do you have good or new ink cartridges in the printer ? Let me know.
Posted on Aug 01, 2007
  • 1 more comment
  • Marcelo Pastorino
    Marcelo Pastorino Aug 01, 2007
    I guess you already tried the cartridge cleaning routine. If this procedure does not fix the printing problem, I am afraid to say it's time to take it to the Dell store or replace the printer.
  • Marcelo Pastorino
    Try removing the printer software and install it again. This time, remove the drivers by going to the printers folder, click on File, select Server Properties, go to the Drivers tab, find the driver for the A920 printer and remove it.
    Then install it again.
    Try also a different USB port if you have it available on your laptop.
  • Marcelo Pastorino
    Maybe you have print jobs pending. Try restarting the print spooler.
    To do this, right click on My Computer, select Manage, expand Services and Applications, click on Services and down the list find Print Spooler. Right click on it an select Restart.
    After this, try removing your printer software.
SOURCE:
A BLANK page prints between each print job
I posted this video a long time ago...hope it helps!
Good Luck!
Feb 04, 2010 | HP Photosmart C7280 Printer
WHEN I GO TO PRINT TO MY HP J4550 THE JOBS GOES TO PRINT BUT IT ALSO SENDS MANY JOBS TITLED SERIAL NUMBER JOBS. THE PRINTER WILL SLOWLY WORK THROUGH THESE(WITH OUT PRINT ANYTHING) IT WILL EVENTUALLY GET TO...
Go into your control pannel and open up "Printers". Right click on the printer you are using and select "Properties". In the box that comes up choose "advanced"
In the middle of the menu box there should be "Spool print documents so program finishes printing faster" below it is "Print directly to the printer"
Change the option to Print directly and then press Apply at the bottom, this will get rid of the "Serial Job Number" that comes up before printing. :o)
Jul 08, 2009 | HP Office Equipment & Supplies
Printing problem
You will need to clean cartridges and printer head with cotton swab and rubbing alcohol. Some printers have a self-cleaning diagnostic setting on them.
After thourough cleaning, print test page and use alignment if necessary.
May 15, 2009 | HP LaserJet III Printer
My HP printer spits out a blank page before printing document
I had same problem with hp psc 2410 all-in-one. Finally ran "HP all-in-one Series Web Release Uninstaller version: 4.1.1.00.1332 (3/20/2007) that I had downloaded several years ago. Then plug and play took over and installed the correct driver that Vista kept insisting I already had.
May 09, 2009 | HP - HP Photosmart 8250 printer
On this page
goes to my printers page right click on printer select open in print queue select print job the click on stop printing
Apr 20, 2009 | Computers & Internet
My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Apr 07, 2009 | HP LaserJet 4500 Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Dell A920 InkJet Printer Logo
1,327 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
