Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
F2 flashing on lower drawer
5 yr old , bottom drawer very rarely used top drawer working fine
  • Anonymous Feb 09, 2009
    hi rescue tech, the motor rotor is frozen and will not come out, help!
  • 145 Answers
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Posted on Feb 08, 2009
  • jvplumber Jan 12, 2011
    thanks 100%
I have a 4 1/2 yr. old bottom freezer Maytag that leaks every few days onto the floor from the front. Temps in top and bottom seem fine. I can see a fine film of ice under the fruit and veg drawers.
Maytag has not changed much in years on how they drain the water. Watch the attached video and you will see what is causing the issue and how to fix it. You can go to various sites to order the parts you need.
Good luck.
Semper Fi,
Z
Feb 19, 2018 | The Optics
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer does not work and bottom drawer flashes on and off
I would need more information to assist you. Drawers run and act independent of each other, the only share to things, drain hose as they connect to each other under the sink, and the power board in which also detects water in base pan. If you have a digital display, what is currently displayed? You lower drawer flashes? What is it flashing F1? F1 is a flood in base pan, F2 is a bad motor. I would need some more detailed information to assist you. Also does you model have panel like wood? This would mean you don't have a digital display.
Please get back to me so I can help you
Jul 22, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Model: Casio TE-2240 Problem: We have 2 cash drawers (tills) for this machine. The upper drawer works fine. The lower drawer is plugged in and opens only when we have the red key in and Z2 is hit (so we...
It sounds like you have a special drawer setup (and a rare model - are you sure it is a TE-2240?). I can't see any settings in my notes for multiple drawers. Do you happen to have a copy of the programming manual in pdf (electronic) form? I can probably solve it for you if I can check the settings.
Oct 05, 2010 | Casio Parts Cash Register PC Desktop
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Lid is stuck in "down" position on the right only.
k the only thing you can do is try starting then stopping each drawer to see if the lid will go back up if not it will even be a hard one for the serviceman. you can't swap the wires like you've done it will cause large problems like a jammed lid sorry.
Mar 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Nov 29, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Code F2
F2= The motor has not
been sensed rotating
 Foreign object has jammed the rotor
 The rotor has failed
 The hall sensor has failed
 The electronic controller has failed
Please check your email
Jul 14, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
158 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
