Question about Microsoft Xbox Console
XBOX 360 green light flashing....
I just got a 360 that when turned on the green light flashes quickly and dashboard shows "opening" but the tray doesn't open. When I push the eject button the tray doesn't open but I can hear the motor cycle as if it was opening then closing. If I use a paper clip to open the tray then push eject the tray closes normally but "opening" still is displayed on the dashboard. I have checked the power and SATA cable and they are seated. Anyone else had this happen and know of a fix short of replacing the drive? I can buy a new drive for around $30 but prefer not to do the flash thing, I would be comfortable buying a new drive and swapping out the board with my existing board but I'm not sure that will solve this problem. Any help will be greatly appreciated!
Bob
  • rlt9999 Feb 01, 2009
    Fixed, at least for now. Took the drive apart and cleaned the drive belt with dish soap and warm water, then boiled it in the microwave for a couple minutes as suggested on another forum. I then cleaned and lubed all of the tray contact point and gears and reassembled. It works like new now.
    Bob
    Sergeant:
    Champion:
  • 378 Answers
Its the drive. Most of the problems with the drive not opening is the belt slipping inside. If you can find a new belt for the motor then change it. Otherwise I would Swap out the board to the new drive and it should solve your problem.
Posted on Feb 01, 2009
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
Tray won't open flashes centre green. Opened
The center of your Xbox 360 has malfunctioned due to overheating which has caused the tray to have various problems. The solution? Simple! Replace the hard drive or send it in to Microsoft!
Nov 26, 2009 | Microsoft Xbox 360 Console
Power supply light keeps flashing green and problems with tray op
under normal conditios power supply light should be a steady green light not flashing if not power supply is might be bad call (800) 4MY-XBOX
Oct 11, 2009 | Microsoft Xbox 360 Console
Xbox 360 fault with console
try switching on your xbox by pressing the disk tray option first?
May 14, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Power's on, dashboard doesn't load, controllers not recognized
Hello. This is most likely due to a failing hard drive. Those hard drives have a limited warranty, so check xbox.com/support for more details. You may be able to have Microsoft replace it for free. Thanks!
Jan 17, 2009 | Microsoft Xbox 360 Console
DISC TRAY WONT CLOSE... PLEASE HELP !!!!1
the drive switch is broken try to buy a new one and then it should work coz my dad works in the computer part
Dec 07, 2008 | Microsoft Xbox 360 Console
Disk tray wont open
get a butter knife and wiggle it a bit. try to really use your fingers and pull on it a tiny bit
Oct 17, 2008 | Microsoft Xbox 360 Console
Disk wont open or close
well i had the same problem with my xbox is i opened the faceplate and pressed the button and if that doesnt work u will have to wiggle it around a little bit if it comes out what u need to do is take some WD-40 and spray some on a cloth or something to wipe the sides of the tray and the silver part of the tray and open and close it a couple of times if it opens and closes put the faceplate back on and it should open and close now
Nov 19, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
3,498 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
