Question about Juki DDL-8300
I have a DDL-5550N-7. It is connected to a Juki SC-1 type FB. Everytime I push the pedal its stops, beeps and on the screen it says E 7 660865. It will not work after that. I need to disconnected and reconnect. ...At first turns on normally. I tap the medal and the needle bobs up and down normaly. After a few seconds its like it jams. I have to spin the side wheel (up) a bit and it feels like something is trying to make it spin but cannot. Then i have to spin it (down) and it jesrks a bit and the needle goes back to its normal position. Then it will work for a few seconds again about five and then it will just beep. show the message "E 7 660870" and stp working.
  • monalisa42 Mar 19, 2009
    same model, lost the instructional manual. I was told that the code for the machine underneath where you can punch them in.  I need the code to reset my machine. If you have this info please forward them to me.  Thanks
Per the SC-1 Engineer Manual:
Error Code E7
The motor has locked. (The motor fails to rotate with controlled even when the motor has been driven.)
Check whether the sewing machine head has locked. (Is is possible to trun the pulley lightly by hand?) ** Correct the swizure of ther machine head.
Check whether the tread has been tangled in the pulley of the sewing maichine.
Check whether the thread has been tangled in the motor pulley shaft.
Check whether the thread has been caught in the hook.
Check whether the proper amount of oil is supplied to the hook.
My guess is your hook and cutter are stuffed with thread and thread dust. Remove the cover plate (2 screws) and the feed dog (2 screws) and carefully clean the junk out. You also likely have thread wrapped aound the shaft behind the bobbin assembly. I use a seam ripper to get that thread out.
Posted on Apr 23, 2009
    Scholar:
  • Juki Expert
  • 176 Answers
Final maybe mduole on main board is dameged and need to replace please contact nearest agent for juki machine
Posted on Dec 06, 2009
CHEQUEA SI EL CABESAL DE LA MAQUINA ESTA OSTRUIDO .O. SI LA CRREA DEL MOTOR SE ESTA DELISANDO.O . SI LAS BOLANTA ARIBA O ABAJO TIENEN HILO.
Posted on Aug 26, 2009
  • francisco orozco Aug 09, 2011
    necesito un pedal de usado en oferta para una maquina del modelo y caja de control arriba mencionados juki ddl-5550-n y sc-1 donde lo puedo conseguir ya que este modelo esta descontinuado sasludos
3 Suggested Answers
  • 3 Answers
SOURCE: Error message on screen.
yes, the control box for sc-1 is damage that is why you getting E7.that need some repair.or you can ask at multytech786@yahoo.ca for service.
Posted on Feb 06, 2010
swimac2011
  • 3 Answers
No. Description andcomponents to be checked Correctivemeasures
E7 • The motor has locked. (Themotorfails to rotate with controlled even when
the motor has beendriven.)
moo :
'JJ +.
Check whether the sewing rnachine
head has locked. (Is it
possible to turn thepulley lightly
by hand?)
sewing machine.
shaft.
hook.
-40•••
• Correct the seizure of the machine
head.
• Remove the thread from the
pulley.
• Remove the pulley and eliminate
the thread from the pulley.
• Check the hook.
• Properly adjust the amount of
oil supplied to the hook.
Posted on Jan 16, 2013
Why does my Juki DDL-5550N-7 sewing machine become hard to control after 15 mins of use? It gets difficult to depart and stop and becomes uncontrollably fast.
indicates a problem motor or motor control problem due to heat from current (power) usage
take it in for a service and proper diagnosis
Dec 14, 2016 | Juki Sewing Machines
Juki ddl 555 lock
Does this look like your machine?
JUKI DDL 5550N Manuals
Jul 07, 2014 | Juki Sewing Machines
How long before changing oil for a Juki DDL5550N-7?
just add oil and clean junk off take up pump filter. no need to change oil there no combustion like a gas engine.
Feb 26, 2012 | Juki Sewing Machines
Where does the oil go in my Juki DDL-5550n-7 sewing machine? I lost the manual and I don't want to buy a new one just for this one thing. Thanks.
hi there
here's the type of oil u need for juki lockstitch machine
( juki Defrix oil No.1 ) you cand found in your local market if NO u can buy light oil white color for industerial sewing machine
best regards
ashraf abozid
Aug 17, 2010 | Juki MO-644D Mechanical Sewing Machine
Feb 01, 2009 | Juki DDL-8300
Juki DDL-8300 Logo
1,659 people viewed this question
Top Juki Sewing Machines Experts
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
