When I plug my tom tom into my computer to downloaded/update maps; I get the screen that asks if I want to connect to the computer, I answer yes. Then the screen comes up saying please wait.............and I do but nothing ever happens after that.
What do I do?
And is it free to update it's maps?
If you are using a Windows 98 or 2000 PC there is limited support for USB devices and you often need to install a driver before the USB device can be connected.
If you are using XP and you can't see the Tom Tom device as another drive then you may have a faulty lead. The lead you need is a USB 'A' to 'Mini B' which can be found at Maplin:
http://www.maplin.co.uk/Module.aspx?ModuleNo=97267
Depending upon the country you are in you could get a similar product from a local electronics store but it will be called the same.
Also check that you computer can see other types of memory sticks. If it can't it may be a software problem or a computer USB port problem. Try another USB port if you have one.
HTH
Peter
