Question about SanDisk Sansa MP3 Player
Screen frozen THE SCREEN IS FROZEN ON MY SANSA & I DON'T KNOW HOW TO UNFREEZE IT AND GET IT BACK TO NORMAL
Hold down the select button and the volume + button at the same time. This should reset it.
Posted on Feb 20, 2009
It is frozen i have the 1g sansa clip mp3 player how do i unfreeze it
You MP3 player may have a pin hole RESET button on the back of the player, use a pin or straighten paper clip and insert it into this pin hole. This button may be able to unfreeze your player.
Apr 04, 2011 | SanDisk Sansa Clip MP3 Player
My sansa mp3 has frozen nothing moves,it is on , how can i dislock it
Hi,the Sansa is a portable media player made by SanDisk. As with all portable media players, there may come a time when your Sansa freezes up for one reason or another. This can be incredibly frustrating. Fortunately, there are a handful of different methods you can use to unfreeze the player.
Instructions
Wait for the battery in the Sansa to die completely. Once the battery is dead, you can plug the Sansa into your computer and download a firmware update for your particular model (see Resources below). You can also remove the battery from the Sansa if you want to speed up the process.
Plug the Sansa back into your computer. If the computer recognizes the device, the player should begin charging right away. This will unfreeze your Sansa.
Hold the power button down for roughly 10-20 seconds. The Sansa should turn off. Wait a few seconds and then turn the player back on.
Hold down the center button and the menu button at the same time. Do this for up to 30 seconds while watching the display screen.
Hope it helped.
Thanks for using fixya.
Jan 12, 2011 | SanDisk Sansa Clip MP3 Player
Frozen at windows mobile screen? How to unfreeze?
Hi,the phone needs to be flashed to be restored back to normal working condition,its infected with a virus,and only flashing the entire phone memory can get rid of the virus,however this can be done by a qualified phone technician in your area.
Thanks and take care
Apr 16, 2010 | Samsung BlackJack II Smartphone
Its just frozen
Well first of all you can try the following steps -
1. Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
2. Go to the Sansa website and download the "Sansa Firmware Updater."
3. Select "Run" when the updater installs. (Installation will take less than two minutes.)
4. Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
5. Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Good Luck!!
Thanks
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
Frozen
Try locating the reset button, it's pin hole size, usually on the bottom, or back of the unit. Depress that for several seconds to reset the unit, that would help.
Feb 07, 2010 | SanDisk Sansa e260 MP3 Player
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
It has frozen so i am unable to use it.
To unfreeze it you must reset it = To reset sansa
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
hope this helps u
all the best
prince
Aug 10, 2009 | Philips SA5125/37 MP3 Player
Sansa e250R is frozen, and no solutions work
I had this problem once. I unscrewed the back with an eye glasses screwdriver, took out the battery and replaced it and that took care of it.
Aug 08, 2008 | SanDisk Sansa e250 MP3 Player
Frozen Mp3 player
push in the middle select button and hold it in. as you are holding it in push the menu/power button and hold it in. you should have to hold them both for about 10 sec. or so then the screen black out and you can release it. that should work. it happened to me once and thats how i unfroze it
Dec 20, 2007 | SanDisk Sansa e260 MP3 Player
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
213 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
