My tv doesn't have a cable jack just one audio video outlet
So how do we hook both up at the same time
  • 10,515 Answers
Ok, not an issue....
The following link would guide you how to set up even if you have just one audio
jack.....
I apologize that i have'nt read that you do not have a cable jack...
http://www.geocities.com/columbiaisa/cable_connections_video.htm
Thanks.
If your problem is resolved, do mark this as well as other threads as fixya.
Take care. Further clarifiation, i am always available...
Posted on Feb 01, 2009
2 Suggested Answers
dave1645
  • 834 Answers
SOURCE: How to hook up VCR to back of TV. There is no
if you look closly you will see one of the red blue green connections say video 1 here they did this just to confuse us and a cost reduction for them
Posted on Nov 20, 2009
What cord do I need to connect my acer notebook to the t.v for netflix
this is pretty easy. Since you're acer aspire doesn't have an HDMI out port, then you're gonna need a VGA cable to connect your acer's video signal to the TV.
This cable should do: http://www.amazon.com/10ft-Resolution-mo...
Now, since it's not HDMI, you won't get audio coming out the TV, only your laptop. But if you want audio out your tv, all you'll need is audio cable, which you can connect to the headphone jack (audio out) and then into the AUDIO IN jack on your tv.
the audio cable: http://www.amazon.com/Cables-Unlimited-A...
After this, just hook it up while your tv is turned on, switch to the VGA channel on your tv, and a window should come up on your tv asking you to configure the settings. For audio go to the control panel while the audio cable is hooked up, go to sound settings, and switch the default audio to speakers, or headphones, im not so sure what it is on a netbook
Aug 16, 2011 | Acer Computers & Internet
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    I need instructions for hooking my VCR to my TV set,
    using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
    good luck.
    May 10, 2011 | Philips Televison & Video
    What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
    Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
    The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
    Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
    Mar 01, 2010 | Coby DVD938 Theater System
    How to hook up VCR to back of TV. There is no yellow video jack. Back of VCR only has one video and one audio jack. What type of cables? Do I use the Pr Pb Y outlets.
    Nov 20, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
    What cables do i use to connect to the tv...the vcr has yellow and white areas to connect and the antenna....it tapes, but i do not get a picture when i play it
    First off, you need to hook up audio and video by using either an A/V cable or a coaxial to connect the VCR player to the TV, for the A/V cable, the yellow, white and red jacks are coded, match the jacks up with the wires, put one end of the A/V cable to the VCR player OUTPUT jacks and the other end to the INPUT jacks in back of TV. For the coaxial cable, connect the OUT TO TV or OUTPUT jack of the VCR to the ANT. IN or INPUT JACK of the TV. Connect the power cables of both units to wall outlets, and then you're set. Good luck to you!
    Nov 19, 2009 | Televison & Video
    Cannot get DVD's to play on our TV.
    It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
    1) COMPONENT VIDEO (Red, Green, Blue)
    If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
    That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
    2) COMPOSITE VIDEO (Yellow)
    If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
    To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
    3) COAXIAL JACK (Antenna port)
    If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
    Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
    Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
    (I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
    May 04, 2009 | Televison & Video
    Problem hooking up DVD player to TV thru my cable box
    Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
    The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
    The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
    One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
    If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
    Feb 01, 2009 | RCA DRC277 DVD Player
    Using the device from the cable outlet
    Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
    Apr 13, 2008 | Terk LeapFrog LF30S
    DVD player hook-up problem
    Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
    Sep 10, 2007 | Televison & Video
    Televison & Video Logo
    457 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
