Samsung flat screen tv 1 y.o. getting no picture just grey....t.v. says no input device "air 34" I have comcast cable. The other two tv's are getting perfect reception. I fell asleep with the tv on "sleep" it was fine. Tonight no picture just gey fuzz. Help please.
    Scholar:
  • 93 Answers
Try to set up channel SEARCH again, this lets some tv`s find the cable channels and lock them in to the available one, also make sure the reception mode is on cable, "air 34" could be an antenna connection mode.
Posted on Feb 01, 2009
My TV is frozen with this picture on the screen. I unplug the TV and nothing happens. The picture below is what it looks like with the TV unplugged. Can you please help?
What is causing the HDMI 1 display on the TV if the "TV" is unplugged?? What you have pictured is more typical of having the "Source" of the TV chosen as the HDMI 1 input to the TV, not the cable input, and having no live device plugged into the HDMI 1 input. Check your manual for how to select different input sources for your TV, make sure all devices attached to the TV are turned on, including the cable box, and try selecting the various inputs until you get the signal you are looking for.
Jun 15, 2015 | Televison & Video
Samsung screen goes grey with green letter? Have Comcast cable
When the green letters appear, turn off the cable box only.
If the screen changes, the problem is in the cable box or hookup.
If the letters stay, there is a problem in your TV.
Jan 09, 2015 | Samsung 6030 Series UN55FH6030 55" LED TV...
Grey border down sides of picture while on AV1
Assuming it's not your device causing the grey lines, just change your aspect ratio settings. Each input has a different set of settings that you can change, so don't worry about messing up the settings on your HMDI 1 input for example if you change your AV1.
Jul 04, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
LG 42LG5 hdmi not working
Have you tried another HDMI cable? The cable may be bad. However, if this is not the case and this is happening across mutliple devices(cable box, dvd player, etc) then you might have a bad HDMI input on your TV. Does this happen on all HDMI inputs on your TV? If you can safely rule out your other devices and the cable itself then you've got a main board problem and would need to get it replaced.
Feb 12, 2009 | LG 42LC2D 42 in. LCD HDTV
Connecting my laptop to my samsung tele
Most common problem is the VGA cable. Make sure you have the 15 pin VGA Monitor cable.
1. Switch off the TV & Notebook
2. Connect the VGA cable to the TV and Notebook.
3. Switch on the Notebook. Set the resolution to 800 x 600 Pixels (Go to Control Panel - Adjust Screen Resolution). Then go to Advanced settings and set 'Screen Refresh rate' as 60 hz in the Monitor tab,
4. Switch on the TV. Go to Source button from the TV remote and select PC as input source. Alternatively, you can go to 'Menu' and select 'PC' as input source. If the connection is made properly, PC option will NOT be GREY anymore.
5. Press Fn + F5, F6, F7 (depending on which Notebook brand you have)
Jul 08, 2008 | Samsung LN-S4051D 40 in. LCD Television
Can't get pc input to work
One thing you might want to try is altering the screen resolution on you laptop. If you are feeding the TV with a resolution higher than it can handle or in the wrong aspect ratio it is quite possible that it will not display a picture.
Let us know if this helps!
Matt
Mar 23, 2008 | Samsung LN-T4671F 46 in. LCD Television
TV
If you are using cable and the signal is connected to the TV through the regular cable wire, then the TV must be in TV mode to work properly. If you are using a cable box with that TV then the TV must be on channel 3. If the screen shows AV 1, then the TV is in the AV mode (red, white and yellow RCA jacks), and you most likely accidently hit the INPUT button on the remote. Pressing 0 3 or INPUT a couple of times on the remote should bring your picture back.
Aug 09, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
