Question about LG Flatron L1751S-SN 17" Flat Panel LCD Monitor
No power to monitor. Completely dead.
After returning to my desk after a break, Monitor was completely dead. No "ON' led indication. Would this be the high voltage powersupply?
  • Dillon Blake Feb 19, 2009
    I repaired the powersupply on the monitor and everythinmg works fine.
snakehead
  • 1074 Answers
SOURCE: monitor repair
the neck board of the monitor needs tube replace it is corroded with carbon if you cannot get a replacementbuy a new monitor.but also check the flyback also it could be faulty replace it check www.dalbani.com for your monitor parts or repairworld.com,good luck.
Posted on Apr 26, 2007
  • 3 Answers
SOURCE: THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
power led green is blinking
Posted on Jul 27, 2009
micromend
  • 748 Answers
SOURCE: LG L19327Q - BF monitor, just went dead. Checked
Something in the power supply has aged to the point of no return. Take the monitor to a reputable repair person or check out my website www.micromendllc.com
Posted on Feb 25, 2010
budmrtn
  • 11361 Answers
SOURCE: my monitor lg 500g model is dead
You need nto open it up and inspect it, here is the service manual; http://online.manualspace.com/computer-monitors-free-ebooks/lg-monitor-service-manual/4721/lg-studioworks-500e-500g-500n-color-monitor-service-manual-314.html
Posted on Mar 14, 2010
pravinbhavsa
  • 348 Answers
SOURCE: LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Testimonial: "thanks a lot :)"
CN-0G606T-74261-23Q-0RHL
LCD (pre the manual you threw away, and my exp.)
1: does it have A.C. power, use a desk lamp to test that jack.
2: does the power lamp come on, ? on monitor.
3: does the OSD work? (press mon, keys? see a box> )
4: does the monitor work on other systems, PC,TV,laptops.etc?
5: try a new cable?
if all 5 fail, or to correct it, the monitor is toast.
Oct 03, 2013 | Dell U2711 27 inch LCD Monitor
Iiyama E2607WS just stopped working - completely dead - internal fuse OK
In most cases there are one or two capacitors in the power supply that open, and in some situations they have a bulge at the top making it easier to spot.
Apr 19, 2012 | iiyama E2607WS 26 inch Monitor
My scepter e240 wont power on is it junk or what
dear,
first of all, check whether the power on/off button light (LED) turns on or not. If it goes on either orange or yellow/green, it means its not completely dead. If its not doing that then its a different matter.
Then you have to check the power cord that can be problematic and need replacement. If it is ok then you have to disassemble your monitor to check the inner fuse that is related with the power supply.
Most probably it is cause by the Capacitor, if it is dead and after checking the fuse!
best of luck!
Mar 31, 2012 | Sceptre X5g-Komodo VII 15'' LCD Monitor
New monitor purchased with a package with compaq desk top, but trying to use with a Acer desk top, screen comes on , but then goes completely dark after about two seconds. If switched off then on, again...
Could be a faulty monitor, or could be missing the driver information for the monitor. Usually when you first connect it will use a generic driver to start but then should automatically download and install the correct driver information for the monitor. Could also just be a faulty cable, power or VGA, HDMI, which ever you are using. Try using different cables first, then you can google search for the correct driver and manually install it.
Aug 22, 2010 | HP Compaq Q2159 21.5-Inch Widescreen LCD...
My ibm desk top is stuck in power save mode monitor won't work
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Nov 20, 2008 | Computers & Internet
My laptop is dead set
when you say dead do you mean nothing no light indicators no blinking curser with a black monitor? because if its completely dead then its the motherboard
Aug 11, 2008 | Acer TravelMate 4000LCi Notebook
Power dies when video signal applied
I fixed this problem by replacing all the electrolytics 1000uF and 1500uF on the power supply/inverter board. All were either bulging or had burst at the bottom rubber seal. This cleared up all problems and I am using this monitor successfully at this very moment.
Jul 14, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Westinghouse L2410NM monitor dead
What about the fuse? Sometimes there is a fuse on the circuit board.
Jul 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
My monitor stopped working
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Feb 16, 2008 | ViewSonic VE175b 17" LCD Monitor
Intermittent power on problem, monitor now completely dead
See other post regarding IC901 Please feel free to RATE me if it helps
Aug 27, 2006 | Dell UltraSharp 1800FP 18.1" LCD Flat...
LG Flatron L1751S-SN 17" Flat Panel LCD Monitor Logo
66 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
