I have a AKAI televsion that i bought today and it doesn't have a cable jack it only has a audio video outlet and we have our cable running through that and we have a cable box but then w can't hook up our dvd player i need to know if there is a way to hook both up at the same time.
    Problem Solver:
  • 9 Answers
If you only have one set of inputs on the television, you can purchase a switch. You would need a two-way audio/video switch, but, you may want to get a three or four-way in case you need to add more devices in the future.
Here is what one looks like:
Posted on Feb 01, 2009
How do I hook this tv up with a cable box?
  1. Turn off and unplug the TV and cable box. ...
  2. Hook up one end of a coaxial cable to the cable wall outlet and the other end of this cable to the back of the cable box using the "In" jack.
  3. Connect one end of the RCA audio/video cable to the back of the cable box using the "Audio/Video Out" jacks.
Nov 05, 2017 | Televison & Video
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
Jul 15, 2012 | Televison & Video
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    No sound. just got connected to direct tv and now no sound. cannot see behind tv to know which red and whit jacks are audio in.
    I would strongly suggest buying a HDMI cable and run it from your DTV console to your TVs HDMI input and this cable takes care on audio and video. This is relatively easy but get someone to give you a hand if you are limited in what you can do. You then must go into the TVs menu and make some simple choices.
    God Bless
    Jul 04, 2011 | Akai LCT4216 42 in. LCD Television
    I need instructions for hooking my VCR to my TV set,
    using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
    good luck.
    May 10, 2011 | Philips Televison & Video
    Cannot get DVD's to play on our TV.
    It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
    1) COMPONENT VIDEO (Red, Green, Blue)
    If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
    That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
    2) COMPOSITE VIDEO (Yellow)
    If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
    To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
    3) COAXIAL JACK (Antenna port)
    If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
    Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
    Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
    (I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
    May 04, 2009 | Televison & Video
    Using the device from the cable outlet
    Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
    Apr 13, 2008 | Terk LeapFrog LF30S
    Cabe hook up tore out
    Most cable boxes have outputs for audio and video. Yellow is the video, red is the audio out for the right side and white is the audio for the left.
    Take a set of RCA jacks and hook it up to the back of the set on input one.
    Yellow to Yellow
    Red to Red
    White to White.
    You need further instruction, respond to this post and I will reply.
    Dec 17, 2007 | Akai PT5492S 54" Rear Projection...
    Connecting TV
    If your tv has line out jacks, run cables to the "play" jacks in the back of the 300. If your running satelite, run the sound cables to the player instead of the tv. If your running a vcr player seperate, you can run those sound cable to the back ot the 300. The video cable would go straight to the tv.
    Hope this helps.
    Apr 17, 2007 | Akai DHT300 System
    Televison & Video Logo
    50 people viewed this question
    Top Televison & Video Experts
