Question about Microsoft Windows XP Professional for PC
Which partition is the best in NTFS & FAT32? - Microsoft Windows XP Professional for PC
  • 58 Answers
For most users running Windows XP, NTFS is the obvious choice. It's more powerful and offers security advantages not found in the other file systems like FAT16, FAT32.
Posted on Feb 01, 2009
How to prepare Transcend StoreJet 25M3 for use with Acronis True Image 2014 backup Software ?
The disk size of 698GB under Windows is correct for a 750GB drive.
This tells you there is only one partition on the Transcend drive.
It is best to reformat the Transcend drive to NTFS, unless you need to also read from the Transcend drive using a computer that does not support NTFS.
I would expect Acronis backup inviting you to reformat to NTFS if you would try using a FAT32 drive for backup. FAT32 has a file size limit of 4GB which may impede backups.
May 03, 2014 | Transcend StoreJet Computers & Internet
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Im copying a game that is 5 Gb and my free space is 160Gb why does it say that the "there is no disk space" is there anything i could do?
1.plz check your hardisk about any virus..
scan your hardisk a good antivirus
and check your partition type FAT or NTFS, FAT32 only support maximum file size 3gb
if FAT32 please convert as NTFS.
please letme know this helpful
Feb 01, 2011 | Western Digital WD Passport 250GB Portable...
Can not get hard drive to convert from fat32 to ntfs
Convert FAT32 to NTFS In Windows XP:
  • Click Start -> Run
  • Enter "cmd" into the text field labeled "Open".
  • Click OK button
  • If you want to convert drive D (D:), enter the command "vol d:" in the command window, to find the volume label for the D: partition
  • Then enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS
  • When prompted, enter the volume label for the partition
Convert FAT32 to NTFS In Windows Vista and 7:
  • Click Start sphere.
  • In the Start Menu search box, simply enter "cmd" and hit enter.
  • If you want to convert drive D (D:), enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS that way can be confusing so an easier way is to download a free software heres the link http://www.partition-tool.com/personal.htm
Oct 20, 2010 | Maxtor Hard Drive
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Toshiba satellite ps141e 181g1w en 256ram 2ghz celeron wont play commercial dvds
Hello tango13
(01) Which partition(s) is/are FAT32?
(02) Which partition(s) is/are NTFS?
(03) Do you mean your OS partition is FAT32?
A Microsoft Windows OS on FAT32 cannot "see" NTFS partitions. Conversely though, it can see FAT32 and NTFS partitions if the Microsoft OS partition is NTFS.
(04) If your OS is on a FAT32 partition, you need to convert it to NTFS if it is to be able to "see" other NTFS (and FAT32) partitions.
(05) If I didn't understnd you correctly, please, in detail, explain the problem again and tell us what the file system is on each of the partitions you refer to.
(06) What did you install from Toshiba OEM discs?
(07) Do you mean that, after performing one reinstall of WinXP Home that you then used the Toshiba System Restore CDs to restore the system again? (effectively wiping out the 1st reinstall of Windows XP you said you performed)?
(08) What precipitated your reinstalling your OS in the 1st place? (I ask because the reason(s) may be connected to the issues you are currently experiencing.)
(09) Your media player and codec issues are not related to your file system issue(s).
(10) How many **DIFFERENT** commercially-produced DVDs have you attempted to play in your laptop's DVD ROM drive?
(11) The DVD ROM drive spinning and not being able to read your DVDs is either (1) a media compatibility issue or (2) the media is dirty or damaged, or (3) a mechanical issue w/ your DVD ROM drive. In any case, I seriously doubt if it is a software issue. IOW, I believe it is a hardware issue.
(12) Make sure of the following:
(A) The movies you are attempting to play are actually on DVD media and not Blue Ray or some other media type that is incompatible w/ your optical drive (DVD ROM drive).
(B) The media (discs) are clean and not scratched, warped or otherwise damaged.
Please, post back here w/ answers to these questions along w/ any more questions, observations, or comments you might have. Let us know also what else you've tried in attempts to correct the issues you're experiencing.
Thank you
BJ @:)
***IMPORTANT NOTE***
Once you assign ratings to the experts' contributions, the problem will be automatically closed and we'll no longer be able to assist you. So, please, wait until your problem has been resolved - *then* rate the solutions and choose a "Best Solution". As long as the problem remains open, we will be able to continue to work w/ you on it.
Apr 15, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
