Question about Kenmore 63942 Dryer
Will heat but will not tumble - Kenmore 63942 Dryer
  • Anonymous Feb 02, 2009
    i need the diagram for the dryer belt.
  • Kenmore Master
  • 4,654 Answers
I can help if I can get the model number for example 914.12784
I do believe the belt is broken, idler pulley bad and will need to be serviced with cost versus replacement determined. Hope this helps you decide, Sometimes its just less expense to replace.....Sea Breeze
Posted on Feb 01, 2009
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
? 2:33
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Nov 28, 2015 | Candy Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
Kenmore 63942 Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
