Question about Juki DDL-8300
Error message on screen.
I have a DDL-5550N-7. It is connected to a Juki SC-1 type FB. Everytime I push the pedal its stops, beeps and on the screen it says E 7 660865. It will not work after that. I need to disconnected and reconnect. ...At first turns on normally. I tap the medal and the needle bobs up and down normaly. After a few seconds its like it jams. I have to spin the side wheel (up) a bit and it feels like something is trying to make it spin but cannot. Then i have to spin it (down) and it jesrks a bit and the needle goes back to its normal position. Then it will work for a few seconds again about five and then it will just beep. show the message "E 7 660870" and stp working.
  • 3 Answers
No. Description andcomponents to be checked Correctivemeasures
E7 • The motor has locked. (Themotorfails to rotate with controlled even when
the motor has beendriven.)
moo :
'JJ +.
Check whether the sewing rnachine
head has locked. (Is it
possible to turn thepulley lightly
by hand?)
Check whether the thread has
been tangled in the pulley of the
sewing machine.
been tangled in the motor pulley
shaft.
been caught in the hook.
Check whether the proper
amount of oil is supplied to the
hook.
-40•••
• Correct the seizure of the machine
head.
• Remove the thread from the
pulley.
• Remove the pulley and eliminate
the thread from the pulley.
• Check the hook.
• Properly adjust the amount of
oil supplied to the hook.
Posted on Jan 16, 2013
  • 3 Answers
Yes, the control box for sc-1 is damage that is why you getting E7.that need some repair.or you can ask at multytech786@yahoo.ca for service.
Posted on Feb 06, 2010
2 Suggested Answers
SOURCE: I have a DDL-5550N-7. It
Per the SC-1 Engineer Manual:
Error Code E7
The motor has locked. (The motor fails to rotate with controlled even when the motor has been driven.)
Check whether the sewing machine head has locked. (Is is possible to trun the pulley lightly by hand?) ** Correct the swizure of ther machine head.
Check whether the tread has been tangled in the pulley of the sewing maichine.
Check whether the thread has been tangled in the motor pulley shaft.
Check whether the thread has been caught in the hook.
Check whether the proper amount of oil is supplied to the hook.
My guess is your hook and cutter are stuffed with thread and thread dust. Remove the cover plate (2 screws) and the feed dog (2 screws) and carefully clean the junk out. You also likely have thread wrapped aound the shaft behind the bobbin assembly. I use a seam ripper to get that thread out.
Posted on Apr 23, 2009
Why does my Juki DDL-5550N-7 sewing machine become hard to control after 15 mins of use? It gets difficult to depart and stop and becomes uncontrollably fast.
indicates a problem motor or motor control problem due to heat from current (power) usage
take it in for a service and proper diagnosis
Dec 14, 2016 | Juki Sewing Machines
Repeat juki sc-1 fb
Usually there is an Error Code List in the manual.
JUKI Sewing Machine Instruction Manual Error Code List
Sep 23, 2016 | Juki Sewing Machines
Juki ddl 555 lock
Does this look like your machine?
JUKI DDL 5550N Manuals
Jul 07, 2014 | Juki Sewing Machines
Problem with Juki DDL-5550N-7 Sewing Machine, Error Code E24
El Drv se refiere a la tarjeta interna que controla el motor, est? se encuentra da?ada.
Email: ingcegadan@gmail.com
May 11, 2012 | Juki Sewing Machines
Where does the oil go in my Juki DDL-5550n-7 sewing machine? I lost the manual and I don't want to buy a new one just for this one thing. Thanks.
hi there
here's the type of oil u need for juki lockstitch machine
( juki Defrix oil No.1 ) you cand found in your local market if NO u can buy light oil white color for industerial sewing machine
best regards
ashraf abozid
Aug 17, 2010 | Juki MO-644D Mechanical Sewing Machine
I have a DDL-5550N-7. It is connected to a Juki SC-1 type FB. Everytime I push the pedal its stops, beeps and on the screen it says E 7 660865. It will not work after that. I need to disconnected and...
Error Code E7
Feb 01, 2009 | Juki DDL-8300
Juki DDL-8300 Logo
702 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
