Question about HP OfficeJet 6110 All-In-One InkJet Printer
My HP printer paper get stuck in top feeder whenever I try to fax
I have HP officejet 6110 all in one printer. Whenever I try to fax something the paper get stuck in top feeder.Any suggestions!
  • HP Master
  • 4,338 Answers
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (My HP printer paper get stuck in top feeder whenev - c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 01, 2009
HP 6110 Officejet all-in-one will not print from the glass top. It will make prints coming from the computer after I press "enter" from message "paper jam". I also can fax. Please help.
You will need to open the top and look inside where the paper travels through and attempt to free any paper pieces that have gotten stuck in the pathway. You probably have a bad board in your control panel, since you are able to print from the computer.
Feb 20, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Feeder problem with Fax
Open the doc feeder and clean the roller and pad with alcohol.
Feb 05, 2009 | HP LaserJet 3055 All-In-One Printer
I have a HP OfficeJet 6210 all-in-one printer...whenever I make a copy by inserting sheet into feeder a long black line appears on the page. It is as if there were a long black line on the original. This...
I have the same printer and have the same problem. I found out though that sometimes this works: when you make a copy, select the best quality option. Again this only works sometimes.
Dec 26, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax
Face up if using the feeder. Face down if scanning on the glass.
Aug 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Original document stuck in feeder of HP OfficeJet 6110 All-In-One
ok...this is not that hard...you'll need to open up the top of the machine, and most likely remove some components. Take a look at this link first though Got backup?
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
Apr 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
482 people viewed this question
Ben Johnson
