Question about Frigidaire PLEF398AC Electric Kitchen Range
F7 code and beeping
I have a problem with my Frigidaire cplef398ccb stove beeping and showing a F7 code.
  • 360 Answers
In version 1 of your model, F7 requires the replacement of the EDC (electronic door control)
in later versions F7 requires the replacement of the EOC (electronic oven control)
Posted on Feb 01, 2009
  • wilfrejavier
    wilfrejavier Apr 12, 2013
    Where I can find the EDC (electronic door control)???
  • Walt Mizell
    Walt Mizell Feb 26, 2014
    How do I tell if it is version 1 or not?
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Error code f7
Hello Samir Girgis - Typically F7 indicates that it is a potentiometer failure error code has occurred and indicating that one of the surface burner switches has failed. Contact a professional to move forward accurately and to assist with the repairs.
Feb 15, 2013 | Electrolux Frigidaire Professional Series...
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
Frigidaire cplef398ccb Flashing F7
version 1 of your unit F7 error code.
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
This does not mean that this is the problem but it is where I would start. EDC is less than a fouth the cost of the EOC.
Please take the time to rate this solution
Thanks,
clarkco
Feb 01, 2009 | Frigidaire PLEF398AC Electric Kitchen...
I would replace the EDC
Feb 01, 2009 | Ovens
GE profile gas stove over does not work....F7 D8 on screen
spectra stove and it is beeping and reading f7 we have unplug it and replug please help me
Nov 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn Air range model SVE47600 Beeping
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
1,802 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
