Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Dark Color on TV. Can't adjust the color correctly
Does anyone know how to fix the color? The screen is dark all of the time. I have gone to setup and adjusted the brightness and color and have also done magic color. Still have dark picture. Please help!
  • 1 more comment
  • eugenemankow Feb 16, 2009
    Having same problem. Tried adjusting the color levels and brightness but all i get was a bright white hazy screen. Please post if you find solution
  • moolieluv1 Mar 03, 2009
    the white is right but the colors are very dark tried adjusting, bought new HDMI cable nothing works
  • Anonymous Mar 28, 2009
    Color is very dark and isn't adjustable in the brightness menu.
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Posted on Feb 03, 2009
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
TV is dark
you can fix this problem. remove your tv back cover, there is a part called Flyback. attaching to picture tube. it has two probs for adjesting focus and brightness.adjust your brightness porbe.
Aug 16, 2009 | Televison & Video
Toshiba 35A44 Screen dark despite max brightness setting some OK
could be the sharpness, color, brightness, or a combination of them
May 05, 2009 | Toshiba 35A44 35" TV
I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Apr 08, 2009 | JVC AV-27530 27" TV
The colors pulsate from light to dark
There was a problem with the sony projection tv's that they called a flicker. Do a google search on your TV and flicker or search sony and flicker. There is all kinds of info about a service bulliten that Sony sent out. There were fixing it at no charge but Im not sure if this fix still applies since the tv's are getting older now.
Jan 01, 2009 | Sony KP-51WS500 51" Rear Projection...
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
Factory setting for the orginal color
u will need a serv maneul this ?s would get alot more go if u make ir preuimum alot pp will tell u how to fix it that cost 5 to post thx nick
Jan 30, 2008 | Philips 50P8341 50" Rear Projection...
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
299 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
