Question about Lexmark X6170 All-In-One InkJet Printer
Scanned documents are huge
I can scan with my Lexmark but the size of the scanned document is huge. How can I reduce the size to what it should be?
  • dbarnett Feb 01, 2009
    How do I do that? I have gone through the menu and chosen standard or automatic for the setting and still no luck.
  • Lexmark Master
  • 684 Answers
Just set the Printer to Factory Defaults
Posted on Feb 01, 2009
How do I reduce scan file size when the resolution is already 200 dpi?
An 8.5 inch wide document scanned at 200 dpi gives you an image that is 1700 pixels wide. This is almost enough to fill a fullHD TV screen at native resolution (1920 pixels wide) which is unnecessary detail. I would use any picture editing programme (many free ones available) to reduce the overall pixel width of your already scanned images by 50 percent. This will automatically reduce the 1MB image to 250k. If you can scan again, use 100 dpi to scan - the result is same; image will be half as wide (and long), and picture file size one quarter of the 200 dpi scan.
Sep 12, 2017 | Samsung CLX6220FX AllInOne Laser Printer
My lexmark prevail pro707 does not compress scanned files, these files become too large to email, how do I set it to compress scanned files please?
On my 901, I can reduce the size of the PDF file by changing the "quality" setting in the scan mode. More specifically, reducing the DPI that it scans at. I also noticed that scanning a document to a wireless network computer, and then scanning the same thing again directly to a flash drive plugged into the printer, results in significant variations of the file size. Perhaps trying different combinations of these things will help you with your problem. Good Luck.
May 29, 2014 | Lexmark Prevail Pro705 Wireless All-In-One...
Lexmark pro205 trying to set scanner for 150 dpi scans to big need smaller
If you're concerned about the file size, uninstall the Lexmark driver and download an updated driver online at www.lexmark.com. That should reduce the file size of the scanned documents.
May 16, 2012 | Lexmark Prospect Pro205 Wireless...
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
Lexmark 7100 scan to .pdf makes file 23 times bigger than usual
> it should be 2-300K
Only if you use Adobe Acrobat (full version) to create the PDF.
All the "text" in the PDF will still be encoded as "scalable text fonts",
rather than as bitmaps.
Anything you "scan" will just be zero and one values,
and the size of the file will be proportional to the amount of "black" (and/or colour) in the scanned image.
Nov 26, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I scanned a document, but when I go to attach the file, it stays in attaching files forever??
Greg, Do you mean that when you want to send it by email it keeps attaching the file forever? If yes then check the size of the scanned document. What happens is that the moment you attach a document to an email Windows start sending it to the email server and that takes time as uploading is slower than downloading. And if the file a large one as scanned documents can be, then it will take that much longer. Try a smaller document first. Size wise small document. If that works fine then you can try larger documents. yes it may be time consuming but there is no price for mental satisfaction. To reduce the size of the scanned document, reduce the pixels in settings of the scanner. or reduce the page size. You will find the document reduced many times over.
Nov 19, 2009 | Gateway Audio Players & Recorders
The document size is too big when scanning
I'm assuming that you mean the scanned image is to big to fit the screen, and not that the document you are scanning is too big to fit in the scanner...
Try reducing the resoloution of the scan, this will redce the size of the scanned image.
EG: at the moment your probably scanning at 1200 dpi, when 300 dpi might suit the application better.
Oct 06, 2009 | HP J4680 Office Jet All-In-One Printer
SCANNING IS VERY SLOW
Absent additional information like scanner, pc, size of document being scanned etc., try to reduce the resolution of the document being scanned. Large documents at high resolution require a lot of disk space, and room to cache the scan until complete. Low disk space can be an issue as well.
Nov 19, 2008 | HP Office Equipment & Supplies
Lexmark X7350 Scan feature
well you are able to scan multiple documents.. but the file size is more.. the way lexmark software writes the pdf file.. the file will be huge for PDF... but not sure if this is a case with any other all in one manufacturer like HP also... but i would assume it would be the same.. so scan the file to MS WORD or any other application that supports multiple pages... so u have it as one file... but if u want only pdf files, then u have to do a little work around like writing the MS WORD Document to pdf format. If the PDF Writer is not installed with your copy of MSWORD then try any free pdf writer software available on the internet.
Aug 31, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
