Question about Sony KP-53S65 53" Rear Projection Television
Tv wont turn on.. :-<
The power light comes on the front of the tv like it's trying to turn on but no luck. I took the back panel off and noticed a part of the circuit board was glowing red and had a small amount of smoke. So I guess my question is, is there a typical part or circuit that commenly goes out on this model Tv ( Sony KP-53S65 )? If this helps to solve the problem, the TV NEVER gets turned off. Thanks in advance for any help you may provide.
It is the capacitor. Look in other forum for part number. I had exact same problem. Was a $2.00 part.
Posted on Feb 01, 2009
No power on LG TV
Could be power supply failure
Oct 16, 2016 | LG Televison & Video
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
TV will not turn on. The lights on front of TV are not lit either(power saving, stand by light). I checked the cord and have power coming in to the back of the TV.
Hello there,
Step 1: check all connections redoing them if needed mean remove the cables and plug everything back in .
Step 2: check the plug, plug something you know works into the plug to Test it
if the plug has power plug the TV back in and try the front panel button to turn on the TV if the TV still doesn't turn on let me know and we try a few more steps
Thank you don't forget to Rate
Jan 25, 2011 | Hitachi P42H401 42 in. Plasma HDTV
My LG decided not to come on the day i went on holiday, i mean no power no lights nothing, come back try again, nothing so i go and buy a new 38'' LG tv, tried the old one once again, comes on fine put it...
It is not you tv its the plug on theb wall. It is probably loose, and causing the intermittent problem you are having. You may notice looseness as you plug it into the wall. Your TV is fine.
Aug 09, 2009 | LG 32LC7DC 32 in. LCD HDTV
Samsung sp-r4232 power button blinks 4 times but tv wont turn on
I have this TV. My father in law tried to turn it on one day and it started making a clicking sound and never came on. So he went out and bought a new tv and gave it to me. It came on when I brought it home and worked for a couple weeks. Then just the other day it stopped working. When you hit the power button the light around it blinks four times and then you here a clicking sound. TV does not come on. Took the back panel off and I don't see any damaged caps or fuses. b435b80e-6d09-419f-a021-9b8a430e0a74.jpg
May 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
Mar 24, 2009 | Televison & Video
Will not come on
Have you try to replace the power supply? I had the same problem with mine then when i took the power supply out I seen that a cap had busted off the solder joint just resolder it back in place and I am using it right now. its been working for 2 months so far
Mar 22, 2009 | Polaroid FLM-2601 Television
Sony KP-53S65 53" Rear Projection Television Logo
176 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
