Question about RCA L32HD31 32 in. LCD HDTV
Screen flickers my new L32hd31 screen flickers rapidly as soon as i turn it on.I tried everything please help.
  • 1 more comment
  • m d Feb 01, 2009
    Actually it started to flicker 45min after. I checked the power cord to see if it was loose.I use other outlets. I went over all troubleshooting tips in the users guide and still continue to get that strobe light flicker.
  • m d Feb 04, 2009
    is there still a warranty on refurbished tvs
  • Devon Sacco
    Devon Sacco May 11, 2010
    OK, did your new TV started flickering when you first turn it on?
  • 1,077 Answers
I would highly recommend taking it back to the store and exchanging it for a new one. There should be a 90 day warranty on it. I'm willing to bet it was damaged before you bought it. In these cases you always want to use any warranty it has. The warranty on new TVs are less that a year. Good Luck
Posted on Feb 01, 2009
  • Devon Sacco
    Devon Sacco Feb 04, 2009
    Oh, yes. There should be. Anything you buy should have 90-day warranty. Refurbished or not. Unless, it was a display model and the sticker said " as is only".
My dell e6400 is flickering rapidly that you cant read anything as from when you turn it on.
Sounds like a damaged display or GPU. Try an external display to confirm either way.
Jun 02, 2016 | Dell LATITUDE Computers & Internet
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Jan 10, 2013 | Samsung 55" UA55C7000 MULTISYSTEM LED 3D...
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Screen display is not stable.screen flickers
CHECK IN BIOS. If the screen is flickering in BIOS then it is hardare issue.
1.Please power ON the notebook, Keep tapping F10 as soon as you power it ON.
2.Press the F9 key to reset the BIOS defaults, it will ask to restore defaults. Hit Yes.
3.Press F10 and save the changes.
In BIOS please check if you can see the flickering. If the screen is same in BIOS then it is hardware issue. If you do not see the screen flickering in the BIOS then please update the BIOS and graphics driver
Feb 09, 2010 | HP Computers & Internet
PS3 does not work in 1080p
My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
-Captain Jake
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
Red column down middle of screen
you will most likely need a new plasma panel
Sep 04, 2008 | Televison & Video
Screen flickers
If you are using your comuter with batteries and have your screen in low brightness may be the tube is damaged and the low brightness is giving you probles. Try setting the screen brigther and see how it goes.
You can also try to locate the FL-inverter board. It is a single PCB and should be just below the TFT.
Disconnect and reconnect the incoming and outgoing connectors a few times. But please be very careful not to damage the cables or connectors.
Nov 09, 2007 | Toshiba Satellite A105 Notebook
RCA L32HD31 32 in. LCD HDTV Logo
332 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
