Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
It takes my washer 3 times to ring out my clothes
Lately when i wash, my washer washes perfectly but it fails to ring out my clothes
  • eschieding Feb 11, 2009
    my washer does not spin effectively my clothes are dripping wet after one spin but if i take half the load out it will spin/ I am not overloading the washer this happens with small loads or big loads
  • Anonymous Mar 31, 2014
    how much clothes can i wash at one time?
  • 750 Answers
Welcome to Fixya
My name is Huum,
You said, lately when i wash, my washer washes perfectly but it fails to ring out my clothes
You have either a bad or loose drive belt.
Or a bad motor unable to spin up to speed!
Sounds like you need a hands on diagnoses !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
Model 3LSC8255EQ. TYPE111. When my wife uses the washing at present,and when shs removes the clothes their a lot of fluff on all the washed items,my wife has then to brush each item which takes a good...
Jan 24, 2011 | Whirlpool Washing Machines
My machine do not spin the clothes
is your washer a direct drive machine, if so check the direct drive coupling down by the gearcase, pump and motor. it may need to be replaced.
Oct 13, 2009 | Kenmore Washing Machines
Mold smell
Use about 1 cup of baking soda plus detergent and run a cycle (hot water). After that, leave the door ajar after each wash to allow the interior to dry out. With the door shut, front loaders have no way to vent the residual water out. Hope this helps.
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I paused the washer to add more clothes when I tried to restart the washer it clicked and then turned completely off
if you add clothes too late in the wash, this happens. The washers know when its to late to wash something effectivly, and they will shut off. sorry, but you will have to rewash what you were washing...
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes must be perfectly balanced or washer will shake and walk
The snubber ring needs to be replaced. It's not an issue of balancing the clothes. The ring is plastic and wears down. Are there white plastic shavings under the washer? Those are from the ring. You can order it on, and there are instructions on how to replace it.
Apr 25, 2009 | Maytag HAV2557 Top Load Washer
Washer wont agitate or spin
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Apr 21, 2009 | Maytag Performa PAV3200
Maytag MAF1200AAW
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Aug 04, 2008 | Washing Machines
Takes 3 hours to wash a load of clothes
make sure you are using soap the is for front loading machines. (he)
Aug 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal De
