Question about HP LaserJet 1020 Printer
HP 1020 The print is slanted on the page a few degrees.
  • David Raczynski Aug 01, 2007
    The trays are installed propertly. It apprears to be related to the stop at the back of the unit. If it is tight, the print is more slanted and the paper is creased along the left edge but only the last 1/3rd of the paper as it exits the printer!?
    Help!!
  • 98 Answers
Check that paper and paper tray are installed correctly. Print from MP tray and check if it's still slanted. If not, the problem is related to the tray and the feed rollers for the tray. Check also these feed roller and separation pad.
Posted on Aug 01, 2007
SOURCE:
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
HP LaserJet 1020 PATCHES ON PRINT OUT
if the patches are random, and not ghost images duplicating down the page, you may need to take out the toner and gently shake it - tilt it right 90 degrees, then left 90 degrees, etc a few times to redistribute the toner...
failing that, the toner could be almost empty.
otherwise, check and see if they are duplicating down the page.. ie the same image defect 3 or 4 times down the page, if so, it is probably one of the drums.. toner or fuser drum...
Hope this info helps.
May 15, 2012 | HP LaserJet 2550L Printer
How to find print count in hp laser jet 1020 plus
To Check the page count follow the following steps: -
-Go to Start, then Printers and Faxes
-Right-click on the HP LaserJet 1020 and Select Properties
-On the General Tab, under Printing Preferences, Click the Basics tab, and select the About button
-Page Count at the bottom of the window
Good Luck!
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Feb 15, 2011 | HP LaserJet 1020 Printer
How to print a config page on a hp 1020
Hello, The HP 1020 Does not print a configuration page like most printers can. There is no button to press on the printer at all to do this.
If you are looking for the page count on the printer. In the printer driver, under the properties, you should find it on the about tab, or click on any HP LOGO you see in the driver.
Not the best news, but I hope this has helped.
The Fixya Team...
Feb 03, 2011 | HP LaserJet 1020 Printer
Hi, I have HP LaserJet 1020 and few days ago three tiny black dots appeared on the left side of the printed pages, just by the border. The borders apper at regular intervals. I found somewhere that it...
dots printed are from the cartridge, you proved that with the change to the old one. If the fuser was faulty, it would repeat the dot 2.5 times down an 8.5 x 11 page
Replace the cartridge and please use HP , remanufactured cartridges fail prematurley and usually wind up costnig more in service and repair/exchanges.
Jan 15, 2011 | HP LaserJet 1020 Printer
Mine hp laserjet 1020 printer was print with nothing word out.
try uninstalling the driver and installing it again.
i need few details what operating system are you using and did the test page come fine?? from when are you facing this prob
Jul 17, 2009 | HP LaserJet 1020 Printer
Hp laserjet 1020
update the HP driver fron internet.
May 04, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
262 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
