Question about KitchenAid KHM3 Classic Hand Mixer
How do I open the case of KitchenAid's Model KHM3WH hand mixer?
    Problem Solver:
  • 6 Answers
On the underside you will find four small plastic plugs that are almost flush with the housing. There are philips screws underneath those plugs.
Posted on Feb 19, 2009
You can see the gear set here: http://www.appliancefactoryparts.com/applianceshvac/help-center/mixers/parts/images/Large/KHM3WH-SECTION.gif
Unfortunately they do not carry the part any longer.
Posted on Mar 27, 2010
  • perona468 Mar 27, 2010
    Add a Comment
What model kitchenaid was made in december of 1973?
3 PointsQuestion about KitchenAid KSM90 Ultra Power Series Stand Mixer
Isn't KSM90 the model number?
Aug 03, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid hand mixer model#KHM5AP beaters hit each other
I have never seen one of these mixers myself but from your description it sounds like the gears are out of timing. Plugs covering screws often get damaged on removal, they are pretty but not really a necessary part. If you cannot get something sharp down the side to flick it out you will need to skewer a hole in the middle to get a bit more leverage on it. When you have changed the gear timing check that the beaters miss each other before you put the screws back in.
Feb 22, 2013 | KitchenAid KHM3 Classic Hand Mixer
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
I need the beaters for the Bravetti 300W hand mixer
I realize this is an old post however I have the same issue. The mixer in my opinion is the BEST on the market, or was as the case is. I found that Kitchenaid hand mixer beaters are very similar and work as well as orignals.
Feb 20, 2011 | Bravetti 35-396 Power Hand/Stand Mixer
I have a kitchenaid ultra power 5-spped hand mixer model khm5twh. the second beater will not stay in the socket. i'm wondering if i'm doing something wrong or if the locking mechanism has given up.
You're not doing anything wrong, the retaining gear probably has one side that is broken and it will no longer lock the beater in place. I have the same mixer and the same problem.I have searched at least 20 web sites that carry Kitchenaid repair parts and the part is no longer available. My best suggestion would be to try a local small appliance repair shop that might have the part on hand.
Feb 09, 2010 | KitchenAid KHM5DH Ultra Power® Hand...
Kitchenaid KHM7T
Hi. Before you take your mixer apart, take a multimeter and test for continuity in the cord. Wiggle the ends of the cord while you're doing this in an attempt to make the cord fail. If it tests out OK, then you must get inside the mixer. If you have the ability to repair the mixer then do so, otherwise take it to a repair place for them to check it out.
Goto www.kitchenaid.com, enter your model # and search for the parts catalog for your mixer. Download the info. This will help you with the project
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 22, 2009 | KitchenAid KHM7T Ultra Power Plus Hand...
6qt Pro Kitchenaid Mixer not mixing
Hi. If you goto the Kitchenaid website you can do a search for the parts catalog for your model of mixer. Download the catalog. It will assist you in disassembling your mixer.
Remove the silver band around the top of the mixer. Remove the top cover and look at the top front of the machine and locate the transmission housing. If it's plastic, carefully inspect this housing for cracks. If you find cracks in this housing, IT is the source of your troubles. This cheap piece of plastic has no business being installed in a high-priced mixer. Your machine probably failed when you were mixing heavy bread dough or cookie dough. When this cover cracks, it can strip the worm gear shaft, its bearings and the bearing seats. It happened to me, and many thousands of other users I expect. Insist on a metal trans. housing for your replacement.
You may be able to have Kitchenaid pay for these parts even out of warranty, just don't tell them that you opened it up. Take it to an authorized repair place and let them assess the damage. Use their estimate to confront Kitchenaid. Be persistent in your complaint, keep asking for a manager to get involved in your case. They paid for my replacement parts even though I was 5 months out of warranty. The higher up you go in the management dept., the more likely you are to have them pay for your parts.
Once repaired, sell it ASAP!
Feb 16, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchenaide mixer model KHM3WH-1
You can see the parts breakdown HERE. It looks like there are 3 screws on the bottom...
Aug 09, 2008 | Food Mixers
KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Jan 07, 2007 | KitchenAid KHM3 Classic Hand Mixer
KitchenAid KHM3 Classic Hand Mixer Logo
1,235 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
