Gemsound power amplifier exa3955 keeps shutting off.
Everytime i add volume from the mixer the amp cuts off and the red fault button comes on..i have amp turned down to a resonable level but the red clip light constantly blinks as if its to loud but it is'nt
It is most likely that the shutting off is an precautionary system response to protect your amp and drivers. check all connections again for wrong polarity.
Posted on Feb 01, 2009
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Gemsound xp-550
A diode/rectifer or voltage stabliser, or leaky capacitor in the power supply.
Also the main transistors in the power amp or if it has an output IC - that!
If you can in anyway disconnect the power supply section from the amp circuit, you can isolate which part is faulty. For if it blows when disconnected from the power amp, you know it's just the power supply that's gone. And if it does not blow - then it's the amp!
Aug 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Gem sound karaoke amplifier #exa1005
please confirm from your speakers cables in good condition and from your speakers.make maintenance to your amp by air blower-clean air filter-keep good ventilation around.after cleaning and good ventilation make test with any media while you are connecting one speaker only and then connect the other one.
Jul 06, 2008 | Gem Sound GemSound PA-585 2-Channel...
SOUND CUTS OFF AT HIGH VOLUME AND POWER LIGHT FLASHED RED
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
Technics SU-V460 Amp Problems
Hi There, you need to eliminate all the connection and surplus items around the SUV-460 amplifier to determine if its the amp or not..
That is disconnect every thing then connect just the speakers and an input to the amp like a CD player or radio input. Then see if the amplifier plays OK thru the speakers on both channels and the balance control works fine....If it doesnt then the fault is inside the SUV-460 but if it all works fine than start reconnecting theemixer panel carefully and recheck all your cables and connections. Its a process of elimination to determine if its a "Box" fault or a cable fault...
Cheers From YUBEUT
Nov 14, 2007 | Technics SUV500 2-Channel Amplifier
Gem sound xp-350 clipping
Hi There,
You have given me a good clue to your problem....
You say that the CD player goes well and does not shut the system down like the Live connections. This is a single input configuration...
This means that there is sound levels coming in from the live multiple connections that are too strong (Loud) for the amp to handle...
Its a good amp you have as its shutting down to protect itself instead of blowing up....
So.... set up for the live show then disconnect all but one of the live inputs and start the live session if its OK, then connect another of the live connections, and see if its OK, if it is then connect another live one connecting each one progressively until the problem occurs again...this last live connection is the one that is too loud in signal strength for the amp to handle causing the shut down...
Solution is to reduce tha signal on that last cable source to a level that stops the shut down...I remember that groups of guitar players have volume controls on each guitar and if these are set too high then this can occur....specially if they are all using the same amp without a controlled "mixer man" monitoring each input signal.
Rember the small meters on the mixing panel which have a green painted area and a red painted area the "mixer man" must keep the each meter needle in the green zone for all the inputs otherwise a shut down occurs.
Hope this helps you...
Cheers From
YUBEUT
Oct 26, 2007 | Gem Sound GemSound PA-585 2-Channel...
125 people viewed this question
 Grubhead
Grubhead
