Monitor 41 oil heater stove lost its heat...
My stove lost its heat... and is flashing 88:88 and orange flame indicator
  • Thomas Hawkins May 11, 2010
    Rosie,
    Have you checked your fuel? Is the fan screen in the back of the heater spotlessly clean? When was the last time you changed your filter?
    We do need a little more about your problem. Is there a flame in the pot when you try to start up? If not is there a thumping noise down by the fuel pump?
    Tom Hawkins
    Bethel, Alaska
    hawkins111@gci.net
We repair Monitor Heater main circuit board and push button panel. call me at 800-782-4449 ask for Dima
Posted on May 07, 2009
Orange lite flashing when burner is on
WHAT MODEL AND BRAND FURNACE DO YOU HAVE ? USUALLY THE ORANGE INDICATOR LIGHT IS SHOWING THAT FLAME IS PRESENT. USUALLY SOLID ORANGE NO FLASH . INDICATOR LAMP COLOR AND FLASH CODES FOR TROUBLESHOOTING USUALLY ON INSIDE OF ONE OF THE DOORS AND IN PAPER WORK THAT CAME WITH FURNACE.
Jan 01, 2014 | Heating & Cooling
Clean heat exchanger
It needs to be removed and power washed. This is not always a DIY project, unless you have a strong back and are mechanically inclined. The heavy sooting indicates that the heater is not getting enough gas. Remember bunsen burners? Same deal, we want a blue flame (non sooting), not an orange flame. The culprit is usually an undersized gas line to the heater, or a smaller gas meter than the heater requires.
Jan 04, 2013 | Hayward H-series Electronic Gas Pool...
I have a MPI 41 monitor heater. k-1. runs for a bit and shuts down..88:88 appears as well as the orange indicators do. they flash together. any suggestions. I also had a repair man here twice and still...
How long is a bit?
Sounds like the clock is faulty - Did the repair man disconnect it from the mains? (Turn it off and on again! ;)
Does the clock have battery backup?
Is the mains power steady?
Is the time set correctly?
Does your unit have child lock?
Dec 31, 2012 | Heating & Cooling
Kitchenaid Model KGSK901SSS. This is a brand new stove functioning at 6500 ft. altitude. In the morning, the flame from the burners is primarily orange flame. Later in the day and evening, the flame burns...
is the temperature in your kitchen a lot lower in the mornings than later in the day. If yes the problem is caused by the orifice shrinking n low temp .
Oct 04, 2017 | KitchenAid KGSK901SSS Gas Range
My mpi 41 moniter heater will come on for a few minutes and then shuts off and the display window flashes 88:88 plz help!
Do you see any flames before the heater cuts off? If not, check the igniter first. You can check it with an ohmmeter or with a clamp on ammeter. If using an ohmmeter, the igniter resistance should be between 10 - 20 ohms. If using a clamp-on ammeter, clip around just 1 igniter lead and you should get 2 -4 amps.
Does the fuel pump start making a thumping noise before the heater cuts off? It makes this sound when it isn't getting any fuel to it. Check your fuel filter and fuel strainer. Be sure to shut off the kerosene before checking either.
If you do see flames before it cuts off, you need to check the flame rod. Clean it with some steelwool or emory cloth. The flame rod is located next to the window on the combustion chamber and has 1 wire going to it. Unplug the heater before checking.
If this doesn't help, let me know what you have found and I can give you more info.
Jan 05, 2011 | Heating & Cooling
Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches...
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Dec 31, 2010 | Heating & Cooling
The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Dec 09, 2009 | The Companion Group Kozy World Portable...
Monitor Heater 41
Our monitor heater was reading E-01. We decided that we would try cleaning the back of the unit and we landed up cleaning all parts of the unit that were visible. We plugged it back in and it works fine again. Thank you for your time.
Nov 03, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
513 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
