Question about Oster 76076-010 Hair Trimmer
Lubricating motor i got a Oster classic 76. just wanted to know where the ball type bearing oiler was located at. it say to put one drop of non-detergent motor oil
  • 22 Answers
Here is schematic for repair and service. This is the A5, it is the animal version of the Classic 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
and if u need parts see the link below for schematic and parts list for the 76.
http://www.clipperrepair.com/parts.htm?mid=106
Posted on Feb 02, 2009
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
What blade do I use with attachments?
In general, Oster 76 clipper combs are compatible with blade sizes 10, 15, 30, 00000, 0000, 000, 1. Many are available at shaveroutlet.com
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
Condenser fan barely runs on ge profile fridge model number pfs22sisbss resulting in an increased temp in the freezer section when I put a small external fan outside to cool the coils temperature has...
The bearings on the condensor fan motor are dry. You can attempt to lubricate the motor with a parifin based oil using either Union 76 "Turbine Oil" or a product called ZOOM-Spout turbine Oiler that is available in most hardware and appliance parts stores. See this link for examples of the oiler: http://www.google.com/search?q=Zoom+Spout+turbine+Oil&hl=en&safe=off&pwst=1&rls=com.microsoft:en-ph&prmd=ivns&source=univ&tbm=shop&tbo=u&ei=sqPZTcivKISEvAPOv-G_Bw&sa=X&oi=product_result_group&ct=image&resnum=3&ved=0CCoQzAMwAg&biw=1003&bih=587
Do what you can to clean off the bearings and armature shaft then lubricate with the oil.
Most of the time lubrication will snap a tired fan out of running slow. On the hard molded motors (encased) lubrication takes much longer as you have to lubricate and wait for the oil to reach the lower bearing deep inside the housing. It is ok to oil from the top and let it run to the lower bearing. It will not hurt the fan. I place the fan on a paper towel for as long as I can and wait for the exvess to drain off before re-installing the motor. On the non-encased motors you can remove the bearings and clean the motor shaft and the bearing then lubricate reassemble and lubricate again.
If your using an external fan... it is OK to use the refrigerator while your waiting for the oil in the motor to drip out. Just make sure there is a 15 minute pause each time you remove power or the compressor will not re-start properly.
Thanks for choosing FixYa,
Kelly
May 22, 2011 | General Electric GE Profile CounterTop...
There is liquid leaking through the bearing on the base that adapts to the motor. Is there a service repair center in my area, my zip code is 60415?
Oster.com shows one Oster service center in Illinois:
(http://www.oster.com/ServiceCenters.aspx?state=Illinois)
Household Appliance Sales and Service 7034 North Milwaukee Avenue
Niles, Illinois
60714-3707
Phone: 847-647-8250
Fax: 847-647-2214
It's a roughly 45-minute drive from your zip code, according to Google Maps. You may want to call them with a description of your problem and see if they can service. There are also several locations in PA that will service Oster blenders.
Apr 30, 2011 | Oster 4093-8 Osterizer Classic Blender...
How to fix the switch on my oster 76 classic clippers
Check out My Video on how to replace Oster 76 Switch at Mannys-Sharpening.com Service You can Trust Since 1990
Jan 06, 2011 | Oster 76076-010 Hair Trimmer
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
My Euro-kitchen range hood's fan/motor is making a high pitched sound after it's been on for a few minutes. What should I do first to try to fix it?
A high pitched sound is usually a bearing that went dry. Lubricate the upper and lower bearing with a Zoom Spout oiler. http://www.apwagner.com/index.php?main_page=product_info&products_id=1547461
You can get this at nearly any Appliance Parts Supply source.
This oil is a 76% paraffin based oil used for motors, armatures, dryer drum rollers etc.
DO NOT use regular oil... or a 3 N 1 oil. The fan motor will eventually lock up if you do.
While your doing the lubrication... check the fan blade tips for wear marks or gouges to make sure they are not striking anything.
Thanks for using FixYa.
Kelly
Apr 21, 2010 | Euro-Kitchen 198B2-36 Stainless Steel...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
551 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
