Question about Kitchen Ranges
Can you get a new heating element for the cook vacuum packaging system chris
    President:
  • 1,214 Answers
You probably can, but give me a make and model number and I can look into it a little more.
Posted on Feb 01, 2009
Convection side of Microwave takes forever to cook.
at 325 degrees should have been cooked so im saying that its not actually getting that hot...\
i think the thermostat might be buggered and not heating up properly or the heater element is playing up
its hard to change them or find witch one it can be so it would be so much easier for you to call a local repair guy
he will say the same one of those 2 but atleast he can test it there and then and give you a price thanks from chris plz rate this solution
Sep 29, 2008 | Microwave Ovens
Refreeze unopened vacuum package cooked ham that has thawed in refrigerator?
It is not best practice to refreeze things and it is the sort of thing that gets people sacked from catering jobs and other food-related employment because in that sort of environment the practice is against hygiene regulations.
We have all done it and mostly got away with it but I wouldn't risk it with a product that will eventually be eaten without further cooking. Refreezing stuff that will be cooked or thoroughly heated after eventual thawing is a calculated risk environmentally and economically-minded people are willing to take but cooked ham is a risk too far unless you intend to use it in soups, hashes or similar.
A heavily smoked ham would probably survive the process in a slightly safer condition than unsmoked.
I hope I have helped you make a good decision.
Mar 01, 2015 | Refrigerators
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Replacing both receptacle and cooking element but it is still not
you just may have shorted your king sealy or robert shaw switches for those burners
check the selection switches behind the control panel
Dec 15, 2008 | Kenmore 95589 Electric Kitchen Range
Brinkman electric smoker
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
Jun 29, 2008 | Brinkmann Smoke' n Grill Electric Double...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
