Question about Kenwood HTB755DV System
Kenwood Home Theater
I have a Kenwood stero with the home theater package (not sure what model but apx. 7 years old) recently my powered subwoofer does not work. I have checked the fuse and power conections and they are all fine. I was told that the subwoofer wont work if the reciver is set on Front Loud and it does not solve the problem. If I use the reciver to check the speaker volume (it just sounds like static for all speakers and its normal) the subwoofer will work and turn on. Once the sound test is done the subwoofer will stay on for maybe 10 minutes and turn off. If I just turn on the reciver the sub will turn on somtimes and other times it will not. Any help ? Thanks
    Novelist:
    Scholar:
  • 84 Answers
Please update your post with any Model Numbers that you can retrieve, especially the subwoofer. Off hand, and with the limited amount of information that you have provided, I would GUESS that your subwoofer is simply overheating, and is being shutdown internally, hence protecting the fuse because no short is detected. If you haven't moved and or vaccuumed/cleaned around or near your system regularly, dust, pollution, pollen...you name it, builds up and can easily prevent electronics from breeathing/venting properly.
Posted on Jul 31, 2007
SOURCE:
Can I connect a Kenwood sw-900 super woofer to a onkyo HT-R391 receiver home theatre sysyem
If your Kenwood super woofer is powered, look for an RCA subwoofer connector on the rear panel of your Onkyo and use that.
Dec 20, 2014 | Audio Players & Recorders
What is the impedance of the JAMO A3SUB.3 speaker?
22K is the impedance listed in the specs but you may have to look on the actual speaker itself to get the impedance of the physical speaker.
Sep 15, 2012 | Jamo HOME THEATER PACKAGE, 4 X A320,...
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
I recently moved and am having trouble getting my phillips subwoofer system model : MMS171W hooked up properly There is a loud background hum when I attach it like I think it should be attached. Any ideas...
This is most likely a "ground loop" and is caused by using two different electrical outlets for the two parts of the system -- main receiver and subwoofer amp.
Try using the same electrical circuit (wall outlet) for all of the equipment in the home theater, using a power strip or strips as needed.
Nov 07, 2010 | Philips Audio Players & Recorders
Problems with int 5.1-Channel Home Theater Speaker System
yes u will need to chandge input jack from mono to stero radio shack $4 part u need y headphone splitter this should fix ur problem
Aug 07, 2009 | JBL 5.1-Channel Home Theater Speaker...
I recently change my 2005 home theater speaker wires to monster cable wires, and now my subwoofer cuts of. Is this supposed to happen?
Shouldn't do this. Thicker cables do draw more power, but sub may not be able to handle the input volume wattage. Double check connections to make sure they are tight and getting full contact.
Jul 16, 2009 | Audio Players & Recorders
No Audio with home theater system
have you tried infra red link?
May 07, 2009 | RCA RT2760 System
No Power
I just recently moved back home to NY and hen I plugged in my subwoofer I have no power
Oct 21, 2007 | JVC TH-C3 System
Kenwood HTB755DV System Logo
160 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
