Question about Samsung SGH-E900 Cellular Phone
Bluetooth not working
My samsung use to automatically detect my handsfree car phone and my blackberry, all of a sudden it does not pick up on these devices anymore. I tried turning all applications off and on, removing and replacing the battery but it is still not picking up on anything. please help, carole
    Problem Solver:
  • 11 Answers
Try *2767*3855# this will reset the software but it will delete your pics aswell though so back them up.....Chris
Posted on Aug 08, 2007
SOURCE:
My blackberry bold 9780 won't automatically connect to my parrot CK3100
when pairing your blackberry, the phone asked to accept connection, just below this there is a small box saying (dont ask again) you must tick this for auto connection. hope this helps
Jan 20, 2013 | Parrot CK3100 Advanced Bluetooth Handsfree...
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Tips & Warnings
Good luck to you..
Feb 01, 2011 | Cell Phones
Bluetooth doesn't reconnect to my Jaguar handsfree
This might solve your problem; go on your blackberry and check in your bluetooth device list for your Jag's handsfree once you've found check the properties of it make sure it says "yes" under the trusted option now if that doesn't work then you need to check in the same properties if "encryption" is enabled if not enable it and you might not have to manully enter it all the time now if it already says enable you could try to disable encryption just to see if that helps. If you have any more questions or more information on this situation just post back and I will gladly help you some more.
Cheers,
Kyle
Jul 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
Connect jabra to blackberry
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT150 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 19, 2008 | Jabra BT150 Wireless Headset
Motorola H700 Bluetooth connection problem
4.Select H700 once a connection is detected.
Tips:
Apr 01, 2008 | Motorola Mobility Bluetooth...
Samsung SGH-E900 Cellular Phone Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
