Question about Dryers
Maytag Quiet Plus 2 dryer
The dryer has stopped heating. Any suggestions for a do-it-yourself fix? I currently have a Maytag Quiet Plus 2 washer and dryer that work great, but was also given a Maytag Quiet Pack washer and dryer and wondering which one is best or which one is newer?
    President:
  • 1,214 Answers
I can't speak for which one is best, but I I can help you fix the no heat problem.
I am assuming it's electric heat. If it is, I bet the element has failed. If you know how to troubleshoot with a volt-ohm meter, I can walk you through the repair.
Let me know if you have the wiring diagram, or can find it on the appliance. Also let me know if you know how to read one.
Posted on Feb 01, 2009
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Jun 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
DRYER WILL NOT HEAT!!! HELP!!!/Kenmore HE3 Dryer-Mod.# 82822102
first its always important that you give make and model as different makes have different repair proceders for repair the easyiest thing to do first trust me is to turn the breaker off then on then try drier and let me know what you found now dont rate me till we are done ok
Jan 02, 2008 | Dryers
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
751 people viewed this question
Top Dryers Experts
