Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
No sound no picture chirping noise
I am pretty sure it is the hv generator but I can not find the part number for this. Help
  • Philips Master
  • 3,459 Answers
Yes - Most likey problem is the HVG in this set. Check the site www.TvRepairKits.com for their chirping set repair kit. Or use the link posted in the previous message.
Posted on Feb 05, 2009
Sound but no picture philips rear projection
ransistor and a failed flyback transformer ( HV Generator) if the flyback didnt get replaced also thats more than likely whats still causinng the issues
Oct 19, 2012 | Philips Televison & Video
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
Oct 06, 2009 | Televison & Video
NO picture NO sound, chirping 60pp9202
Chirping isnt caused ny the ICs and resistors. The chirping is usually caused by the Flyback ( HV Transformer) or the HOT transistor.
Aug 21, 2009 | Philips 60PP9202 60" Rear Projection...
Blinking green light in front, high pitched chirping noise, no picture.
u may have a high voltage problem , 1 may be the flyback transformer , or may be u vertical circuit , need to take it to do tv shop for service
May 08, 2009 | Televison & Video
Squeeking noise from unit when u switch set on but no picture?
Sounds like the HV generator will need to be replaced. Can you tell if the sqeaking is coming from this component without touching it?33c0a28.jpg
Feb 01, 2009 | Televison & Video
Picture and a ticking noise from behind the television
ticking sound is hv shut down. electronic sweep circuit or power supply problem. need tech.
Dec 04, 2008 | Philips Magnavox TS3260C 32" TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
154 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
