I have a CX51QF3 Sharp television and have just moved interstate. How can I tune the TV at the new location?
  • 6 more comments
  • charlywal Feb 01, 2009
    Sharp CX51QF3 - How do I tune in channels?
    It does not seem to have a menu item for auto sacanning.
    I cannot find a yellow function key on either the remote or the TV
    There is no auto channel select on the menu - only a fine tune option
    How do I initiate the auto tunning process?
    There is NO auto program feature that I can find - otherwise I would not ask!
    Thanks taran 2005 - there is only one remote - no tune in remote - and no SET button - nor a green light
    Thanks MrScary66613 - best answer out of the lot!!!
    President:
  • 1,990 Answers
Welcome to Fixya! You may need to General Search your New Area Online to Find the Stations and Numbers and Enter the Stations Manually. Please Rate My Response! Thanks!
Posted on Feb 01, 2009
  • 10,515 Answers
Follow thw below procedure for sharp t.v
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Thanks.
    Scholar:
  • 140 Answers
Press menu on your remote control or television.
Toggle to the "auto program feature"
Press ok..
The television should go through an automatic setup of the channels.
  • 744 Answers
Hi there is a auto tune option available on all sharp televisions.. so u no nedd to worry about tuning process...
    Master:
  • 416 Answers
Just connect what ever you have internal antenna or cable or digital converter to antenna in of your TV, go to menu input selection
antenna or cable, go to channel select auto channel search and here you go
Good Luck
  • 790 Answers
Hello!!
Sharp TVs often require you to press the TV Tuning preset key which is a yellow function key.
  • 122 Answers
You should be able to go into the menu and scan for new channels...this is easiest done with the remote...thank you and please rate my response...
  • Gary Loney
    Gary Loney Feb 01, 2009
    you tune the same way you did at your old location......
    President:
  • 1,214 Answers
You'll probably have a menu setup capability that will let you do a new channel scan.
Reply if you can find it, and I'll search for a manual.
Auto tuning digital tv lcd Sharp LC-32LE345X
Maybe your Sharp TV wants you to go back to setup and go through the whole routine again.
Nov 21, 2013 | Sharp Televison & Video
Tuning tv
Consult the owner manual or Google to find one--if a specific issue let me know.
Dec 03, 2012 | Toshiba REGZA 32RV530U LCD TV
I have a sharp aquos LC32AF3x which was working fine . We have moved and now it will not tune into stations. I have used the same connections on another tv and that tv locates the stations when tuned but...
Your TV has to be able to sense local station signals as part of the tuning process. there may be a problem with the antenna or cable connection.
Jan 05, 2018 | Sharp Televison & Video
New Sharp LCD tv LC42SB45UT just hooked up and
Try tuning it manually instead of Autostore...(check system if compatible)
Dec 08, 2009 | Sharp LC42SB45U 42 in. LCD TV
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Sharp Tv, can't tune in channels
Sounds like he accidently put it in parental lock, the remote should have the "key", the user instruction book will have the answer also. Hope this helps
Aug 16, 2007 | Sharp 14U-FM1 14" TV
Sharp television DV5165H
can you use the menu if so i go to ch select then choose auto programming on either cable or tv then the tv scans all the channels and sets accordingly
Aug 01, 2006 | Orion STV2763 27" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
