Question about Samsung Techsan LM1770A 17" Monitor
LM1770A POWER ADAPTER 12V
I'M LOOKING FOR AN POWER 12V ADAPTER FOR MY LM1770A SAMSUNG MONITOR, I NEED TO KNOW WHICH MODEL(S) AND WHERE CAN I BUY THIS, PLEASE!!
  • PIERO TUCCIO Aug 01, 2007
    Tanke you very much,when someone does not know something, is very important to have aid. Thanks by resolving this, for my a important
    problem.
  • Samsung Master
  • 12,061 Answers
Ok well the Power adapter is not really that special.. what you need is a Centre Pin POSITIVE 12volt at say 4 amp power supply unit. I would get it from Ebay.. perhaps even being able to get an exact one from Ebay.. Othewise try the Samsung site and purchace direct. Look here for an idea. http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=power+supply+for+LCD&_nd1=See-All-Categories
Posted on Aug 01, 2007
SOURCE:
I need a power supply for a 57-c3 monitor. 12v dc 85w
I guess you could be looking for something like these
http://www.coywood.co.uk/lcd-power-supply-flat-screen-mains-adapter-adp-65db-12v-7a-2222-p.asp
http://www.power-adapters.co.uk/12v-dmtech-4-pin-power-supply-adapter-p-4668.html
http://ezlaptopadapters.com/12v-7a-4-pin-power-supply-adapter-p-4006.html
Apr 11, 2011 | Planar DOME C3 20.8 in. Flat Panel LCD...
I have a 17" Scanport
You may buy any adapter with 12V, however, make sure the new one also matches at least the same Amp. of the monitor. Universal laptop adapters are ok to use.
Nov 07, 2010 | Scanport 17" LCD Monitor
Need to buy a replacement power adapter for this model, can you tell me what the dc output and connector size is - Zyxel P660HW-D1
Dc output is 12v and 1amp.
You can buy power adapter for Zyxel P660HW-D1 from nearest computer shop or from internet.
It's power adapter needs 12v and 1 amp.
Let me know if you need further assistance.Thanks for using FixYa.
Jun 13, 2010 | Zyxel P660HW-D1 Router
I have a Gateway monitor that needs a power cord
http://cgi.ebay.com/NEW-12V-2-5A-Adapter-Power-Supply-for-LCD-monitor-Cord_W0QQitemZ220405347970QQcmdZViewItemQQptZBI_Electrical_Equipment_Tools?hash=item33512eb682
Or you can just type in 12v 2.5A LCD Adapter in an Ebay search. You can usually find a bunch of buy now power supplies that come with cords for a decent price. I've been using one of these for a year or so on my monitor.
Nov 14, 2009 | Computers & Internet
Need a power cord I think my wife tossed it???
You can buy a regular power cord at the store such as wal-mart, staples, bestbuys. Most monitors have a standard power cable, similar to that of the computers.
Apr 25, 2009 | Samsung Techsan LM1770A 17" Monitor
Mag lt456s power supply bad
The correct one would be 12v @ 2.5 to 3 Amp.
If the set used less current than 1 amp it would be in milliamp (500ma which is half an Amp)etc.
As long as you get one that is 12v @ 2.5 to 3 amp it will be fine.
You could buy one with a higher current rating like 4,5,6 or more Amp's as long as it's 12v DC. The set will only use the current that it needs to function so I higher current won't hurt. It's the voltage you have to make sure is correct. If you do buy one with a higher current rating it will probably last longer because it wont get so hot.
Mar 12, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Samsung LM1770A 17
Most probably the Power Supply, generally is in these things... perhaps the Electrolytic Capacitors have Dried out and gone bad and need to be replaced, often all I do is replace every large Electro on the Power Board, (Often with much higer Temperature and spec Caps) and that "Fixes" it..
Jul 13, 2007 | Samsung Techsan LM1770A 17" Monitor
Need AC/DC adapter for monitor!
Hi inkedpandora, http://icm.computercci.com/pgi-productspec?PSO080 This one should work for you it's the same voltage and amperage as your unit. 19VDC 3.16A Any standard power cable from an old printer or computer will work with one of those PS's. The only thing you need to check before you buy is the polarity of the barrel connector. I looked on the net but could not find out that info so look at the jack where the power plugs into the monitor. You might see a little diagram showing a + and - signs. If the line coming off the + sign goes to the semi-circle than the barrel is positive and if the - goes to the SC the barrel is negative. Ask them before you buy which way that one is. As long as they are the same you will be able to use that PS. Good Luck, Dude
Nov 22, 2006 | Liquid Video A170E101 Monitor
Samsung Techsan LM1770A 17" Monitor Logo
198 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
