Question about LG BG8000ER Air Conditioner
LG BG8000ER Air Conditioner Problem!!
I've lost the instruction manual to install the air conditioner and i cant find it anywhere would it be possible if someone could give me a copy of the manual to install this air conditioner? thanks if you can.
I am looking for a wiring diagram for my L G air conditioner
Posted on Jul 19, 2008
Go to ca.lgservice.com find find owner's manuals under quick links and then fill in your product information to obtain a copy of the instruction manual.
Posted on Aug 01, 2007
Does this air conditioner need water
Air conditioners don't need water. if it is runnibng properly and blowing cold air it will produce water on the condensing coil. Look at the coil. If you see a lot of ice, turn the unit off and wait until the ice melts. If the ice returns it is probably low on freon. This must be taken care of by a licensed air conditioning tecnician.
Nov 17, 2012 | LG BG8000ER Air Conditioner
My lg 15000 er air conditioner is blowing hot air i could hear compressor starting for five minutez of cooling the n shuts off and hot air again i have cleen filtered and cleaned coils inside part
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up and you reset it by turning it off and then on again...
The unit will need to be recharge or replaced...
Here isa tip that I wrote about how to add refrigerant to a air conditioner or coolingsystem
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 27, 2010 | LG BG8000ER Air Conditioner
Air conditioner leaking water outside and inside the window. what should I do?
first try to tilt it more to the outside if this does not fix the problem the drain holes are plugged between the inside coil and the outside and possibly the hole on the outside. Its usually best to remove the unit and wash it out outside. try not to get water on the switches.
Aug 08, 2010 | LG BG8000ER Air Conditioner
My LG could not cool a small room.why?
sounds like the refrigerant has leaked out , check the warranty in the manual.
Phil
Jun 10, 2009 | LG BG8000ER Air Conditioner
Air conditioner donot work.
THERMOSTAT SWITCHBOARD IS MOST LIKELY THE CAUSE DREAMGREENSERVICES.COM HAS ALL YOU NEED TO FIX ALMOST ANY PTAC AC UNIT 770-233-9987
Nov 25, 2008 | LG BG8000ER Air Conditioner
LG LWHD 1200 HR Air/Heater fan will not start.
may be a bad fan motor or loose wire, however some units have dip switch settings on the circuit board preventing the fan from coming on.
Dec 19, 2007 | LG BG8000ER Air Conditioner
LG BG8000ER Air Conditioner Logo
649 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Steve F
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
