Question about Honeywell Programmable Thermostat Heater
HONEYWELLTL8230A1003 THERMOSTAT, THE SCREEN GOES BLANK THEN ON F
INSTALLED THE THERMOSTAT PER INSTRUCTION, NO CONNECTION FOR THE GROUND WIRE. AFTER TURNING ON AND PROGRAMING TIME AND DAY AND BEFORE COULD READ INSTRUCTIONS FOR SET UP ON THE TEMPERATURE CHANGES THE SCREEN WOULD GO BLANK AND BACK ON REQUIRING RESETING OF DAY AND TIME.ETC. UNABLE TO USE TO DETERMINE IF HEATER WORKS. IT IS FOR ELECTRIC BASEBOARD HEATING.
  • don_nancy76 Feb 02, 2009
    THERE WAS NO GROUND WIRE ON THE THERMOSTAT OR ANY PLACE TO CONNECT THE GROUND WIRE COMING OFF THE HOUSE WIRING TO THE THERMOSTAT. AND YES THE WIRING IS SET UP AS DESCRIBED AND THE WIRES WERE TESTED USING A CURCIT TESTER FOR BEING THE POWER SOURCE. INSTRUCTIONS WERE FOLLOWED TO THE LETTER. THANKS.
  • Mark Egan May 11, 2010
    The inner most black and white wires are to be connected to the power side, and the outer most are to be connected to the heater side of the circuits.
    Are you sure you got connected in this way?
    The green ground wire should connect to any ground wires that are in the box. Those ground wires should be a 3rd conductor of both the power side cabling, and the heater side cabling. It's not that important at this point, and is there for protection grounding for prevention of shock.
    Also make sure you've gotten good connection of all wiring connections.
    Reply back and I'll help you solve this.
    President:
  • 1,214 Answers
Well, it's an be only one of three things then (in order) -
1) Bad wiring connection, particularly the middle pair of white and black wires connected to the supply wiring, or
2) One of the breakers or fuses has tripped or blown, or
3) Bad thermostat.
If 1 is OK, check 2 (double check if breakers, sometimes they don't look tripped when they are), and lastly, take the stat back and get another one.
The ground is secondary, and it is assumed your living in a house where 14-2, 12-2, or 10-2 with ground was NOT used. If it was, hook up the ground. If not, it's OK. The grounding requirement was added to the NEC after your house or whatever was built. It is not electrically active or needed for this circuit.
Reply back what your findings are. Will be glad to help!
Posted on Feb 03, 2009
Suzuki wagon r good battery blank ignition
Either bad connection at battery or your ground wire is missing/damaged.
Jan 16, 2014 | Suzuki Swift Cars & Trucks
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
HONEYWELL RTHL2310/RTHL221 THERMOSTAT AIR WILL NOT COMEON
Recheck your connections.The wire colors may not have been wired in the standard way when HVAC system was installed. I remember the instructions on my Honeywell thermostat(replaced mine about 2 months ago) stated that you should look at the wire LOCATIONS on the 'stat you're replacing and tag the wires according to this,not the wire color(too late in your case).You'll have to verify the wires.Disconnect them(don't worry about noting where they were as it's not right anyway).Using an A/C voltmeter,locate the hot feed to the 'stat(ground one lead of the meter at a nearby outlet and look for 24v on any of the wires).Tag it as "feed".Now,touch this to each wire until you find one that turns on the ventilation blower and tag it.Try the other two,one of them should turn on the outside A/C condensor unit(this is the A/C wire).The remaining wire's gotta be the furnace,but verify anyway.This should be enough to get you back on track(don't feel bad,the instructions in my 'stat confused me a little,even though I've replaced mine a couple times before).PS- I think the blower fan wire goes to the terminal with the little factory jumper wire-this is so you can set it up to run the same fan in heat or A/C(factory setup) or remove the jumper to run a seperate fan for each(highly unusual setup but possible)
May 25, 2012 | Honeywell Programmable Thermostat Heater
The screen of my 32LG30AR goes blank after 30 minutes of operations but audio is there. The Service center says that complete panel needs to be changes while local repaiers says that the card needs to be...
disconnect the connection on connector which going to inverter board
not all leave the 24 volts wire and ground and lamp on rest of them cut the wire and see if tv stays on if it does then the inverter board defective
but company dont sell these boards thats why they said to replace the panel it comes with panel but you can leave the wire secure and use tv
if tv stays on.
Mar 02, 2012 | Televison & Video
I have a Trane XE1000 High Effeciency heat pump, installed in 1989, in the house I am renting. I'm having issues with the air and I think I hooked the thermostat up wrong. I have 8 wires coming out of...
The white wire goes to W2, the green wire goes to G, the red wire goes to R, the orange wire goes to W or O, and the Yellow goes to y. If this is a digital thermostat you will have to go to the set up mode to set the system up for a heat pump or the reversing valve in the outdoor unit will be in the heat mode. If there is a C on the thermostat you will need to put the black wire there on some Trane models.
Jun 06, 2011 | Heating & Cooling
The thermostat (I installed myself) is not working. I have no heat. It's a combination heat/ac. I read instructions. I'm thinking maybe I have a wire connected wrong. before I go any further, I'd like to...
Wiring color to Thermostat Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g. Hope this helps you. Thanks.
Jan 09, 2011 | Heating & Cooling
I need to replace an old Thermostat that just has 3 wires coloured Red, Blue and Yellow. The Honeywell THR830TUK Thermostat I have bought shows 5 wires on the diagram. I'm not sure which wire goes into...
The honeywell THR830TUK thermostat does not require a neutral as shown in the instructions.Connect the LIVE to terminal "1" and your YELLOW SIGNAL wire to terminal "3".
Connect your EARTH (if you have one) to the EARTH connection on the top left hand corner of the thermostat and blank off your NEUTRAL wire with a block connector.These instructions were supplied to me by Honeywell Customer Support.Hope this helps.
Jan 08, 2011 | Heating & Cooling
How to wire Honeywell thermostat RTH7500 from old Weathertron GE
You have a control board on your furnace, there is a 3 amp fuse there, that 3 amp fuse needs to be replaced. You most likely touched a wire even by accident and blew the fuse. You will have to remove the door \panels to get at it. It looks like a normal car fuse
May 31, 2010 | Honeywell Electronic Programmable...
I have a RTH2310 with a gas furnace. Where do we hook up the black red and ground
It's is a very hard question because I'm not the one whom installed you unit. Some installers do it their own way because there is no industry stranded way. Some use Black wire as common and some use the Blue wire. Although things are this way, I'll still try to help but don't hold me to it. I would have to be there before I could really help. Sorry but here is my best guess.
Black goes to you first stage of heat or W1
Red goes to R, it supplies your thermostat with 24 volts from the transformer (Without it, nothing works)
Ground should be the Blue wire otherwise known a Common
Oct 22, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
292 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
