posted by Trumple on Jul 31, 2007
Hi, my labtec headset worked fine up until today. One of the speakers just stopped working. And adcive on a fix?
Thanks
Solution #1
posted on Jul 31, 2007
whilst the headphones are in use flex the cable from the non working speaker bit by bit down to the jack you should find it will work at some point down the cable as I suspect after long use you will have a break in the cable once this is located just splice the cable and make the break good with a soldering iron, hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Labtec 342 Headset
Email this problem
Email this problem
Can you Help with these Headsets problems?
Repair Service
Find Headset Repairman Near You:
