Question about ViewSonic G90fb 19" CRT Monitor
Viewsonic Monitor and the text is not black but grey.
The text has almost a halo effect behind it while the screen is not white but a light beige where it use to be white.
Try to log in safe mode and reinstall the display adaptors or uninstall them and reboot
Posted on Feb 01, 2009
Display in black with one line in 1/4 of the top
Hi.
Please try to connect other monitor to your CPU.because I know the problem is in your video card graphic.also change your screen resolution to 1024 by 768.
if same problem again. need to check-up your viewsonic p75f+ crt monitor. some parts of your vertical video section capacitor leakages.
Jun 13, 2011 | ViewSonic P75f+ (Beige) 17" CRT Monitor
My monitor has no 'red' anymore. Everything is black, white and blue with grey
Failing internally, unless you suspect the cable or graphics card?
Repairs are possible, but unlike the older CRT monitors, expensive and sadly uneconomical. CRT screens do go over time and the loss of a colour channel is usually the 1st sign it needs replacing
Mar 22, 2011 | ViewSonic VA1912wb Monitor
Background "halo light effect" when using XR-10-XL in 16x9 mode
Do you mean there is a dark grey outline when using it in 16x9 mode? This happens with my projector too. Try using dark (or black) masking around the screen.
Aug 20, 2009 | Sharp XR-10X Multimedia Projector
Viewsonic E70f 17
Check the horizondal out put transistor if it is short replace the transistoror or replace the flyback transformer.
May 01, 2009 | ViewSonic E70f 17" CRT Monitor
My viewsonic ve170m display for 2 seconds and go back to black
Your power supply has gone bad you need to take the back off. Check the power supply look for blown caps the tops will be raised replace them that will fix the monitor.
Mar 16, 2009 | ViewSonic VE170m (Beige) 17" LCD Monitor
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
Grey white screen and that is all
It looks like you will have to get the backlight replaced/fixed.
May 20, 2008 | Gateway FPD2275W LCD Monitor
Repair manual
Problem solved! The main power thingy (the thing with the big red wire coming out of it) was all black and dusty. There was 'soot' all over the whole insides of the monitor. I concluded that this monitor should be laid to rest, and a new flat-screen monitor erected in its place.
Nov 18, 2007 | ViewSonic G220f (Beige) 21" CRT Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
ViewSonic G90fb 19" CRT Monitor Logo
147 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
