Question about Dishwashers
Dishwasher problem have a fisher and paykel nemo dishwasher . it starts beeping near the end of the cycle and wont stop , the only way to stop it is to turn it of at the wall .
  • 2 more comments
  • Anonymous May 18, 2009
    the machine won't stop beeping unless i turn it off at the wall. when i turn it back on it has stopped but when i do another cycle the same problem happens, the beeping begins and won't stop.
  • Ender Wiggan May 23, 2009
    I start the dishwasher and 10 seconds into the cycle it stops and starts beeping, it won't stop until i turn it off at the wall.
  • mike950 Jun 13, 2013
    My F&P Dishwasher is doing the same. Only other thing is that the LEDs on the control panel aren't working and the Power and Go/Pause buttons don't have any effect. Machine hasn't been used much and I wonder if it has died of boredom...
    I've got the same problem. In addition all the LEDs on the control panel have gone out and the 'Power' and 'Start/Pause' buttons don't work. Machine isn't used much and I'm wondering if it died of boredom?
I had the same problem with a fisher paykel nemo dishwasher beeping at end of cycle, as im a mechanic i was curious to pull it apart and see how it works, i pulled the main control board out and unscrewed the three screws holding it all together and inspected the circuit board, and what did i see, a dry solder on the blue relay box or something, resoldered it, reassembled it and now works a treat, hope that helps
Posted on Jan 26, 2011
  • MrMurr Jul 30, 2012
    Exactly the same issue on my F&P Nemo model 820. The water was not being heated as power not making it to the element. I too resoldered a dodgy connection on the back of the blue relay box to fix it. Cheers!
  • peter diglin
    peter diglin Jul 18, 2014
    my F&P beeps at the end of the cycle continuously, pump keeps going and the only way to stop it is by turning it off at the wall. Does a great job of the dishes though.
    New Friend:
Posted on Jul 18, 2014
2 Suggested Answers
SOURCE: fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Posted on Dec 13, 2009
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher & Paykell Nemo model 820 won't start
It sounds like the interlock switch on the unit isn't working, it is a switch than closes when you lock the unit to start the wash cycle. there may be something interfering with it. look to make sure you have a good seal when you lock the unit if not then something is blocking it from sealing properly this will make the buttons give a beeping sound and not work. Hoe this helps.
Nov 18, 2013 | Dishwashers
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
Fisher n paykel nemo dishwasher won't go. Sounds
Dec 13, 2009 | Fisher Dishwashers
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
1,732 people viewed this question
Top Dishwashers Experts
