FixYa.com
Tags:
Emerson Quiet Kool 6GC53 Air Conditioner
Humidity
posted by missreba on Jul 31, 2007
My Emerson Quit Cool does not have a drain hole. It makes the room very humid. Why?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 05, 2007
FixYa! (100)
KOakaKO
Rank:Wiz Wiz
Rating: 83%, 137 votes
An air conditioner of this type always has standing water sitting in the base-tray of the machine as it's running. They're designed to work that way.
However, if the unit leans slightly in toward the inside of your house, then the water in the tray can be deeper than it should and/or add extra humidity to the inside air.
These units are designed to be installed so that they lean slightly to the _outside_ of the window or wall-hole where they are mounted. This way the standing water drains off to the ground outside and isn't so deep on the inside of the unit that it adds too much humidity to the inside air.
Check the mounting of this unit to make sure it leans slightly toward the outside. Also verify that any notch or drain hole on the outside end of the unit, intended to guide draining water, is not clogged with debris (which could also cause the standing water in the unit to be at too high a level).
Also verify that the "vent" is closed, if this unit is equipped with said vent opening. An open vent panel can allow humid outside air inside as the unit is running.
Hope this helps! ;)
Rating Locked! (?) missreba has rated this solution as FixYa!
Can you Help with these Air Conditioners problems?
Air Conditioners
I need wireing schematics for
I need wireing schematics for... Answer This...
Air Conditioners
GE UNIT - AC/HEAT PUMP
does it have an overflow valve... Answer This...
Air Conditioners
Gas Furnace locks down in
Gas Furnace locks down in half... Answer This...
Air Conditioners
pilot light on my new
pilot light on my new yorker... Answer This...
Air Conditioners
Hampton Bay fan AC 552
Hampton Bay fan AC 552 Replaced... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
