Question about Hitachi 53UDX10B 53" Rear Projection Television
Convergence problem
Replaced both conv ic's and 6 resistors picture is much better but now have double image on numbers not picture double image is blue
  • 1 more comment
  • dennismannle Feb 09, 2009
    yes but its not helping.picture is worlds better after replacement but still getting double images on the outer 6 inches of each side of screen center is good.
  • Anonymous Apr 30, 2009
    I have a similar problem on my 53udx10b. I recently replaced 3 blown resistors (rk50, rk54, rk58) and both IC's, but continue to have the same problem. Colors won't align, blue is bowed top and bottom while red is bowed left and right. I can move both red and blue up, down, left and right, but can't move blue up high enough to get it centered with green and red.
  • tom woodward
    tom woodward May 11, 2010
    can you move the convergence lines with the remote ?
  • 42 Answers
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
1. (3x3) Press “STATUS” 5 times (only works
when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
convergence.
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
to write data to ROM memory. ROM WRITE? is
displayed to alarm system that ROM will be
overwritten with new data. Press the PIP MODE
button again to write displayed data to ROM.
(8) DATA WRITE TO ROM will take approximately 4
seconds and no picture will be displayed.
(9) Green dots will be displayed when operation is
completed.
(10) Press MUTE to return to convergence pattern, then
confirm again convergence is acceptable.
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
PRESS “STATUS”.
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
green.
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
Posted on Feb 10, 2009
Fuzzy picture help 55" rear projection toshiba
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused trouble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is installation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Mar 04, 2011 | Toshiba Televison & Video
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
My jvc rear projection 48" tv is showing double images, what can I do to fix this problem
In the menu do the auto convergence. If still bad replace the convergence ics. Also check resistors around the ics. You can remove the front grill and access the conv board from the front. Small board on the right. It popps out.
Mar 25, 2010 | JVC AV-48WP74 48" Rear Projection...
Picture shows double images in red and green with red and green bands across the bottom of the screen
convergence ICs need replacement there are two STK392-110 Convergence ICs in that model, Also check the 2.2 ohm 2watt resistors there are 6 of them in that model.
Jan 22, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Distorted Color and geometry of Picture
Sounds like a convergence IC problem, you will need to replace them'
Heres a quide
see the before and after pictures to verify your problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 15, 2008 | Televison & Video
Double Images
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 02, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Convergence problem
replace the convergance ic chip on the board below the crt of whtever color is not working
Aug 29, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture loss
sounds like the convergence ICs and resistors due to the double image. You need two convergence ICs both STK392-110 ICs and the following six resistors. (2) 3.3 ohms 1watt resistors, (2) 1.8 ohm 1watt resistors. (1) 1.8 ohm 1watt resistors. (1) 3.9 ohm1watt resistor. You can get replacemnet ICs and resistors at the following link and they provide free instalation instructions so you can do the repair yourself. Heres the link.
Aug 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Convergence concern
They are located right next to the Convergence ICs easy to spot. There are numerous identical resistors.Usually 1 or 2 will be open.
Feb 10, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Double vision with a lot of yellow color
This looks like bad convergance. If only one color is affected it may be one of the convergance IC's. It is best to replace both IC's though. If you change the IC's then check the resistors next to the IC's. Use the exact part numbers. STK392-110 IC's can be upgraded to a STK392-180 for better heat strength. (That is why they blow, too much heat generated. Use a liberal amount of Silicone Heat sink compound.) A shorted IC will usually blow a resistor. If a bad resistor that isn't changed it will look like the new chip is bad. Make sure that you use the same wattage and the exact value (Ohms). Your convergance will not be right with an off value resistor. This info works for about any other brand Projo TV. Cheers, Lee http://www.crazycomputers.com
Jul 21, 2007 | Hitachi UltraVision 55HDS52 Television
Hitachi 53UDX10B 53" Rear Projection Television Logo
273 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
