Question about Kenmore 15522 Built-in Dishwasher
Dishwasher door won't open all the way
Since just 2 days ago our dishwasher door only opens about 80%. I don't know how it comes apart or what to look for as to the problem. Any suggestions? The ID plate says this is a Kenmore Model 16798792. Thanks for any help.
    President:
  • 331 Answers
You;ll need to remove the "kick" panel first. Use a 1/4" nut driver or socket. Then open the door and remove the 2 phillips screws that mount the dishwasher to the underneath of the cabinet. Then scoot the dishwasher out about 6 inches or so. You'll be able to use a flashlight and look closely at the door hinges and spring assy. to see what's hindering the full extension of the door. You MAY need to take the water valve off to get it to scoot out so you can work on it. Don't take the copper pipe off of the valve, just remove the screws that hold the valve onto the frame. And don't forget to KILL THE POWER TO THE DISHWASHER PRIOR TO SERVICING!
Posted on Aug 01, 2007
SOURCE:
Dishwasher just quit one day, controls or lights do not work, I have power so that is not the issue,
The first place I would suggest that you look, is to make sure your door is closing all the way. Make sure nothing has gotten stuck down at the bottom of the door and no silverware is stopping it from closing. You dishwasher has a door open/ajar switch that in a part of the door lock. If it is even just a little bit open, it will stop power to the timer and will not come on at all. Unless you are very comfortable with electricity, I would suggest you do not open the cabinet up as you are mixing two very dangerous items. Electricity and water.... you could receive a very bad shock or even death if you don't get it right the first time. If you are ok with the possibility, I can give you additional info.
Oct 30, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
AEG/Electrolux dishwaser error code iC0. When I swich on the dishwasher the sound appears - bzz and display shows iC0. Maybe someone knows what does that mean. Thanks
Hi, I Had a similar problem and fixed it by unplugging the cable that goes to the thingy that shows that time remaining on the floor. If your floor time display stopped working properly a while ago then maybe you have the same problem. The 4 wire ribbon cable that goes to the display was cut over time by a plastic cable clip in door when the door opens and closes... To fix take the door apart. The cut in the cable is right at the bottom of the door... follow the black 4 wire ribbon cable back to the control board. Unplug & wrap in a little installing tape and stick out of the way. I've not had a problem since... the time display does not work, but the dishwasher does... I think the tipping forward tips suggested by others may have worked for a few days in my case by wetting the cut cable and restoring enough of a connection to make the machine work for a few days...
Oct 03, 2011 | Dishwashers
About 80% of the time, the soap container does not open.
I know you're joking!! I should tell YOU how I fixed it so you can charge others to give them the answer !!!
Sep 22, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher door locked shut
Apply firm pressure to the door while you press or pull the release latch. The screws holding the latch assembly could have loosened. Tighten screws after you get it open.
Jul 07, 2009 | Dishwashers
The detergent door doesn't open
Please reply your exact model number so we can see what the door looks like.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Door mechanism
wind metal strap around plastic bush and hook above hinge
Sep 08, 2007 | Candy 24 in. CD622 Free-standing...
Open Questions:
Kenmore 15522 Built-in Dishwasher Logo
3,778 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
