Question about Apple iPhone 3G
How do you turn of phone - no calls and turn off just roaming?
How do I turn off the phone when I board a plane? Also, when I travel I need to be able to turn off the roaming?
Thanks
  • Apple Master
  • 4,338 Answers
Enable Airplane Mode on your iPhone by choosing Settings, then turn airplane mode off.
This will disable the ability to:
Make phone calls
Send or receive email
Browse the Internet
Send or receive text messages
Stream YouTube videos
Get stock quotes
Get maps locations
Get weather reports
When in airplane mode you can still:
Listen to music and watch video
Listen to visual voicemail
Check your calendar
Take or view pictures
Hear alarms
Use the stopwatch or timer
Use the calculator
Take notes
Read text messages and email messages already stored
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 01, 2009
  • JDTec
    JDTec Feb 01, 2009
    Turn Airplane mode "on":
    Enable Airplane Mode on your iPhone by choosing Settings, then turn airplane mode on.
WHY SHOULD I CHOOSE HOME ONLY ON MY VALET TRACFONE? DO I NEED TO CHANGE THIS WITH TRAVEL? IS THERE A CATCH?
I believe this choice is to determine where most of calls/texts your will be made to. Choosing Home will designate your home area code as your most frequently called area (no roaming charges) while Travel will probably allow you to choose a different area code as your most frequently called area. When you call out of your chosen area code roaming charges apply. Example, if your current phone area code is 123 and you move to area code 321 you may want to change your Home or Travel designation depending on where most of calls are made to since you can't actually change your phone number.
As for your other question, you don't need wi-fi to text. It's like making a phone call, you simply choose message instead of dialing a number. Phone calls cost 1 unit, while text messages cost .30 units. (Units are the dollars you spend to buy minutes divided by the total number of minutes you receive) Hope that helps.
Oct 14, 2014 | Tracfone Wireless ZTE Valet
HOW DO i CONNECT RELATIVES IN IRELAND AND SWITZERLAND WHEN I TRAVEL TO iTALY AND fRANCE
go into yer phone settings and turn on international roaming, watch out for the costs thou as they charge ya heaps.
Nov 15, 2017 | Cell Phones
Why is daughter not receiving texts in Malta from me
It could be that her roaming it set to off. This would not have the iphone connect to cell towers there. Also could have to do with imessage or many other things more info is needed. Also turning on data roaming will add a fee to your bill so be careful and use at your own discretion.
Use cellular networks on your iPhone and iPad while you travel...
Sep 03, 2014 | Apple Iphone 4s I Phone 4 S Factory...
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
How do I set the roam on my Samsung Omnia 2?
You need to contact your cell phone provider to enable roaming to the country you wish to travel and obtain connection settings.
Their company may be establish in the country you are travelling to or may have partner phone company in that country.
Sep 02, 2010 | Samsung Cell Phones
Wheelchair tips
Here are some tips
  • When booking your flight: Use a travel agent who is experienced with planning trips for travelers with disabilities.
  • Make your reservation far in advance.
  • If possible, choose an airline with planes that have 30 seats or more - larger planes offer more accessibility.
  • Pick a flight with no changeovers. Call ahead to alert the reservation clerk that you will be traveling with a wheelchair.
  • Arrange for boarding assistance or an aisle chair to get to your seat. And if you can't walk, request an aisle chair during your flight for bathroom use.
  • You should arrive at the airport At least an hour in advance so you can store your fold-up wheelchair on-board. (There is usually room for one wheelchair on a first-come basis).
  • When possible, use gel batteries, as wet batteries must be removed and stored in a separate sealed container.
Sep 14, 2008 | Excel 3000 Wheelchairs Removable Desk...
Roaming indicator
Reason for the lock code is because roaming charges are costly. In case you lose your phone and the person that has travels out of the country with it, he/she will not be able to make calls.
Mar 19, 2008 | Samsung SCH-u740 Cellular Phone
755p issues
For the first part, make sure you sync the phone and are you using after you pick the ringers.
Second Part, I had this problem make sure you press ok i was using other keys like back assuming it would not, what service do you have because most current plans do not charge roaming unless you use more than 50% of your minutes while roaming.
Masalama
Sheeraz Khan
Jan 12, 2008 | Palm Treo 755p Smartphone
Apple iPhone 3G Logo
262 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
