Televison & Video Logo
Posted on Feb 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't hook up Cable and Dvd player.
I Have a AKAi televsion I just bought and I need to know if there is a way to hook up Cable and a Dvd player at the same time.
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Feb 01, 2009
Anonymous
Contributor
Level 1:
Answers
37
Questions
0
Helped
33309
Points
68
Even without being able to see the back of your television, I'm assuming like most new TV's there are multiple inputs for video and audio and HDMI inputs which carry video and audio on the same cable. Your best bet for highest quality video and sound is if you use the HDMI inputs. Whatever the cables you use connect the cable box to one set of inputs, and the DVD player to another set of inputs. Then with your remote you'll have to select the input that you want to watch. For example, you can connect an HDMI cable to input #1 on your TV, from your DVD player; and component video cables (blue, green, yellow) and stereo audio cables (red and white) to input #2 on your TV, from your cable box. When you want to watch a DVD select INPUT 1 on your remote, when you want to watch cable select INPUT 2 on your remote. I hope this clears it up for you. Ask if you have any more questions. If this was helpful please rate me. Thanks.
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782743
Points
6681
Check this link to get instructions on how to connect the cable TV box and the DVD player to your TV.
Anonymous
Level 3:
  • Master 10,515 Answers
Anonymous
Master
Level 3:
Answers
10515
Questions
Helped
2934585
Points
31530
What cable do I need to hook up a Samsung dvd writer sh-s182 to my Akai dps16 with scsi?
I suppose you would need a SCSI cable with the correct number of pins that match your scsi ports. Some have 50 pins some have 80 pins and some have less than 50 pins. Count your pins and go from there. Have you ever done this procedure before? Did it work?
Hooking up your surround to your television
Does your TV have an audio output? if it has, then connect that to your Insignia 5.1 ch. audio input.
I hooked up the dvd but I get a picture but no sound
audio cables need to be hooked up as well not just a video cable.
usually red and white and clearly colored on the output side of the dvd player and the tv. input is on the tv output is on the dvd, also if you are using a fiber connection (optical sound) you will need a fiber cable from the dvd to the tv.
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
I have a AKAI televsion that i bought today and it doesn't have a cable jack it only has a audio video outlet and we have our cable running through that and we have a cable box but then w can't hook up our...
If you only have one set of inputs on the television, you can purchase a switch. You would need a two-way audio/video switch, but, you may want to get a three or four-way in case you need to add more devices in the future.
Here is what one looks like:
DVD Hook up-Olevia 266-T11
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
5helpful
3answers
How to hook up to cable television
you will need a component or hdmi cable/satellite tuner for this tv.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
