Lost manual for Dimplex N835 air con
I've lost the manual and now have a symbol coming up that I don't understand, might be that I have to empty the water try at the bottom. Also not sure if I should be running this with the windows slightly open like evaporative aircons. Is there anywhere I can get another copy of the manual and can you help me make sure this is running at its best.
Just had our 10 day over 40 dec C!!
thanks
SOURCE: LG BG8000ER Air Conditioner Problem!!
go to ca.lgservice.com find find owner's manuals under quick links and then fill in your product information to obtain a copy of the instruction manual.
Posted on Aug 01, 2007
SOURCE: Water spillage in Dimplex portable air conditioner
Hi Leanne,Bung stays in and you dont take it out until the red light (4th on right on top of unit) comes on, then you empty it taking bung out and use tube to get the water out. It will probably take some time (days of continuous operation) for the light to come on, depending on your humidity etc. For easy emptying, wheel the unit to a bathroom or outside where if it spills a bit it won't matter.
Ours is working okay although it just stopped blowing cold air and is only blowing room temp air. we have guests tonight and its hot! I came here looking for a solution to my prob and found yours!
chhers, Les.
Posted on Jan 08, 2008
SOURCE: Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Posted on Jun 23, 2008
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
SOURCE: bought open box product didnt come with owners manual. Just wondering what the evaporate option does on it. Does it make it blow colder air or no
The evaporator button turns on what is similar to a conveyor belt on the back of the unit. The two rollers, one at the bottom of the tank and the other is above the blower, is just like a conveyor belt, but instead of a black belt it's a white absorbent cloth. When turned on the rollers start moving the white cloth in a rotation into the tank at the bottom that is filled with water and two ice packs (you get 4 w/ it) and I put in a tray of ice cubes at night. . As it goes down into the tank it absorbs cold water and as it goes up the blower is drawing in cold liquid molecules from the white cloth, then the cold liquid molecules are drawn through the blower and out the front of the unit. This conveyor system does remove so you can remove the tank to add or change the water. This is also a filter on the back. When the Evaporator is off the conveyor just is not on. I hope I made any sense, lol. I am not a technical writer and spent 15 mins trying to explain it. I hope I helped.
I just purchased one at WalMart. I realllly like it. I have a room w/ no windows. One little air conditioner at the end of the apartment so I get none of the cold air. I heard about this so I got it. I love it! At night I don't have to have all these fans that stiffen my neck and makes it sound like I am in a airplanes turbine. Just this baby with two frozen packs at a time. I put a tray of ice cubes also at night. You do not feel water on you but it's definetly much cooler then a fan. Especially in humid conditions. People who say it sucks or does not work. They probably expected to get a stand alone air conditioner for $80 instead of $300.
The customer service # that came w/ mine is 866-876-4332 9-5 cst M-F or MideaUSA@aol.com
Posted on Jun 22, 2009
Need to change from cooling to heating for a Kelvinator KSR27G split sys air con. Have tried ourselves using the remote, but we feel it is not operating correctly. No manual came with it when we purchased...
The cooling symbol on the remote is generally an "icicle" , the heating is a symbol of a blazing sun. Make sure you have selected the right mode. Also check the filters... if they are dirty, you wont get decent heating from any air con.. cheers,
BTW, I believe that electrolux have a site you can download instruction books.
Jul 14, 2011 | Heating & Cooling
I have lost my manual for my bio tech plus air con. my air doesnt seem to be cold at all, not sure if i have right setting, on the remote there is a sun, snowflake auto and i think a raindrop, which should...
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Feb 01, 2011 | Heating & Cooling
Anyone have access to a dimplex DAC15006RC portable air con manual?
You can download from:
www.dimplex.de/en/downloads/installation-instructions.html
Helpful?
Dec 26, 2010 | Heating & Cooling
HAVE A DIMPLEX PORTABLE AIR-CON HAD IT FOR 6 MONTHS . LATEY WHEN YOU TURN IT ON AFTER 5 MINS IT BEEPS AND THE CODE E7 KEEPS FLASHING. CAN NOT FIND THE MANUAL SO DONT KNOW WHAT IT MEANS..PLEASE HELP
The E7 message indicates that the unit is full of water and needs to be drained. The drain plug is on the back of the machine towards the bottom on the right as you face the back of the machine.
You can empty the unit by pulling out the black stopper and tilting the air conditioner slightly to drain. Make sure you do it over a container or outside though, there's quite a bit of liquid.
To replace your instruction manual, you can find a pdf version of it here:
http://www.glendimplexdealer.com.au/Resource1049853HJDUFOS023X/Owners%20Manuals/Cooling/Instruction%20Manuals/IM%20for%20Portable%20Air%20Conditioners/Instruction%20Manual%20for%20PAC%2010-6-09.pdf
Aug 22, 2010 | Heating & Cooling
I HAVE JVC MEMORY CAMCORDER GZ-MS100AA MODEL NO N835.I HAVE BEEN LOST ITS BOOKLET & CD. HOW I CAN PLAY & SAVE THE VIDEOS FROM HANDY CAM TO MY PC
Aug 08, 2009 | JVC Everio GZ-MC100 Memory Card Camcorder
How much water should be put into a Dimplex Portable Air Conditioner DAC15HH? The user manual does not say how much. There is a clear strip on the side which runs the full height of the unit which allows...
On your unit do not put water into it. Only when the water level reaches the line do you empty it. The collection of water comes from the air conditioner condensing the water and collecting it in the tray. Hope this helps you. ken
Jan 06, 2009 | Heating & Cooling
Instruction Manual
Pat
Jun 21, 2008 | Heating & Cooling
chhers, Les.
Jan 01, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
429 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
