Reddy R155D Utility Heater
Problem for Reddy R155D Utility Heater
Reddy pro155 runs for 3 to 5 seconds
By www_fordkid6 on Feb 01, 2009
I just bought a pro155 reddy heater used. We plugged it in the guys garage ran good. Took it home (temp about 15 degrees) plugged it in ran then shut off. Unplugged it, it turned on about 5 seconds later ran for about 3 seconds and shut off. It is repetative every time. Any tips. Thank you Fred
Clarification Request
Posted by marksteel1 on Feb 13, 2009
my heater has a sparkplug
Same Problem
Feb 05, 2009
-   I have the same prolem , It was used when I bought it, I knew about the problem,and thought it would be a quik fix.I thought I could just clean sparkplug and change the fuel in witch I did.that wasnt it I was wondering if it was the coilpack Im not sure can anyone please give me some advice? -   marksteel1
Feb 02, 2009
-   I have A 150,000 kerosene reddy it worked fine one day . And now it has no spark. It is getting fuel but no spark. Coil pack bad ? -   vukan777
Best Solution
posted on Feb 06, 2009
Very Helpful)
tbugger
Rank: Guru
Rating: 90%, 70 votes
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Reddy R155D Utility Heater
Questions and Unsolved Problems for Reddy R155D Utility Heater
Do you recommend Reddy R155D Utility Heater?
Answer
Answer
how to replace wick on the dyna glo rmc 95 c2 kerosene heater
Answer
Carrier furnace, pilot does not light, fans run for a couple minutes and then flashes code 31
Answer
furnace turns on pilot light starts lights up all barrels and then shuts off immediatly. Carrier... (More)
Answer
Nova has a intertherm furnace and needs a circut board for it the model number is E1EH O15HA on the... (More)
Answer
Looking for wiring diagram/technical specifications/instructions for Armstrong home heating and air... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy R155D Utility Heater:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
