Question about Saeco Magic De Luxe Espresso Machine
Can't make coffee
Low water light remains on Will not make coffee Water is full Attempt to Drain machine will not
  • 29 Answers
A couple of things to check. On this model there is a magnet floating in a small compartment in the water tank. If this is stuck to the bottom or not there it will not tell the machine there is water and will not proceed. By not able to drain the machine do you mean that when you turn the knob to have water go through the wand nothing comes out? If so then the missing or defective magnet would do that. If the magnet is good and there and the no water light still is on and steady then you may have a problem with the main board. If the no water light is on and flashing this is another problem. If this is the case please advise. Thanks
Posted on Aug 01, 2007
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    The water res. is full all the right buttons are pushed but coffee won't brew. What do I do next? It only has a small drip.
    1.Power off machine.
    2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
    3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
    4.Reassemble KCup cradle and reinsert it back into coffee maker.
    5.Power on machine.
    6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
    7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
    8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
    9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
    10.Set Auto-OFF, if preferred.
    Mar 25, 2011 | Keurig Elite B40 Coffee Maker
    B70 keurig wont heat up
    1. Power off machine.
    2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
    3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
    4. Reassemble KCup cradle and reinsert it back into coffee maker.
    5. Power on machine.
    6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
    7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
    8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
    9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
    10. Set Auto-OFF, if preferred.
    Nov 28, 2009 | Keurig B70 Coffee Maker
    After the machine beeps "ready" the filter is still full of water
    Make sure the lid is on the caraffe, or else it will not make the proper contact with the filter basket (and hence the filter basket will be forced into the closed position).
    Sep 29, 2009 | Cuisinart DCC-1200 Coffee Maker
    Low water light stays on
    If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
    If coffee lights are solid, turn off the machine, let it cool off and try the above again.
    Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
    Hotpoint washer dryer BWD 129 stopped and won't drain or spin
    unplug for 40 minutes in an attempt to reset the ECU.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 15, 2009 | Washing Machines
    Part 2 -Flashing water light - will drain water but will not make coffee
    Blinking light often means pump is not delivering water. Possible blockage from corrosion. Can also mean a valve blocked.
    Do you hear the pump run?
    Dec 11, 2007 | Saeco Magic De Luxe Espresso Machine
    Coffee maker doesn't brew full pot
    you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
    Dec 10, 2007 | Cuisinart DCC-1200 Coffee Maker
    Saeco Magic De Luxe Espresso Machine Logo
    59 people viewed this question
    Top Saeco Coffee Makers & Espresso Machines Experts
    eyecam
    Marvin
    Marvin
    Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
