Question about Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I have a Sharp Aquos # LC-45GD4U. It now suddenly turns off by itself and stays off until I turn it back on. This happens while watching live TV or playing back a recorded show. Ideas?
I subscribe to Time Warner and have a Scientific Atlantic HDC8300 cable box.
    New Friend:
  • 12 Answers
Check the ventilation fins on the back. Sometimes they get obstructed with dust and then heat builds up. The TV then shuts down to protect itself from overheating. You can use a blow dryer to blow it out.
Posted on Feb 01, 2013
SOURCE:
SOURCE: Turns itself off
Sharp LC-13AV4U - turn it on and in ten seconds it turns off.
Happens every time.
Any Ideas?
DO THIS AT YOUR OWN RISK!
This is NOT a fix, this is a permanent band-aid.
All you need is a phillips head and tiny diagonal cutters....
Heck, even a nail clipper would do it.
Just disable that faulty protection shut-down circuit!
Remove all the screws from the back cover
and look at the main board with the
unplugged! power cord towards you.
In the upper right corner of the board, you will find
a tiny red-striped zener diode, labeled as D409.
It is to the right of an electrolytic capacitor marked C403.
Snip this diode, at either end, or snip both ends and discard it.
Re-assemble the TV.....and you just got your tv back!.
I only run mine when I am sitting in front of it,
I never leave it running unattended....just in case!
Don't blame me it yours burns up....but mine is just fine.
The Robot Doctor.
Posted on Dec 13, 2008
  • 5 Answers
SOURCE: Aquos Turns off by itself
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, you can order the part over EBay, not hard to install just unscrew/unplug --- plug/screw..
Posted on Aug 16, 2008
SOURCE: Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Posted on Jan 10, 2009
SOURCE: Programming the Acquos Remote
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Mar 01, 2009
highspeedsan
  • 61 Answers
SOURCE: sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Posted on Apr 30, 2009
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
NEW SAMSUNG CABLE BOX TIME WARNER &TIVO SERIES 2
the IR is located next to the power button and you will have to select pioneer as your cable box brand and it will work fine
Jul 28, 2010 | Samsung Televison & Video
How do i get it from air to cable on the tv it is olevia 42 inch
if you are subscribe to any satellite service provider, this doesn't work (ex. Direct TV), you can only get channel's thru your antenna when you are subscribe to a cable service provider (ex. Cox Cable or Time Warner Cable)
Dec 28, 2009 | Olevia LT42HVi 42 in. LCD Television
Change default channel on cable box
Called the cable provider, Time Warner, and used the "settings" menu to navigate to power on channel, where I selected the default channel.
Nov 13, 2009 | Atlantic Scientific Network connector
We have hdmi cord connecting our comcast box to our Lg hi def tv. we get video, but no sound through the cord. we cant get the sound and the picture at the same time
Make sure that the cable box set set up menu has the sound selection as HDMI. This is needed especially if it is a Scientific Atlantic Cable Box.
If this does not correct the problem, call LG Customer Service to get a local Service Facility to take a look at it.
Hope this helps,
Skyassoc
Oct 21, 2009 | LG 37LC7D 37 in. LCD HDTV
TVGOS (TV Guide on Screen) stopped working on Time Warner.
split your input cable line and connect one end to your digital input and the other to your
analog or air input.
Jun 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
May 12, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
No sound time warner cable
Time Warner Cable just sucks!!!
Feb 02, 2008 | Computers & Internet
Sharp Aquos LC-45GD4U 45 in. LCD HDTV Logo
503 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
