Question about Akai LCT2715 27 in. LCD Television
Tv will not turn on by remoye or by manual button
  • 2,296 Answers
Most power up failures are due to a defective power supply. The failure is with capacitors that lost their dielectric strengh and the circuitry is unable to provide clean DC power to the main board and other circuits.
I repair them, if you need further assistance write to jah2mil@hotmail.com
Posted on Feb 01, 2009
I cant grt the menues to come up? eather by the remoye or buttons on the front.
I have a similar problem the screen goes dim after the Haier welcome screen ? do you know of a fix ?
Thanks
Apr 08, 2012 | Haier HLTD7 7 in TVDVD Combo
I ahev a Westinghouse flat screen tv would like top set my cable remoye to operate it I need the code numbers
you can find the remote code number at:
http://westinghousedigital.com/support/remote-codes/
I managed to find the one that worked for me!
Jan 10, 2011 | Westinghouse 26" LCD Flat-Panel HDTV
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
My crime stopper remoye start will not work the
try programing the remote again by going to www.crimestopper.com and to the support tab choosing manuals and manuals again with the model number from the unit under your dash find the manual for that model for any other question you can contact their tech support at 800.998.6880 ext 210
Oct 03, 2009 | 2-Way Remote Starter
Can't get my dvd player to work with my tv
if you hooked it up with the red white and yellow cables, you have to change the input with the remoye, you have to find the input betton on the remote, hit that, if the input box pops up on the screen, hit it again, keep doing that untill you see a picture, make sure the dvd player is on,
Jan 10, 2009 | iLO 2600 Television
Wii remote working but no arrow
Try moving closer to the TV. Where the remote is pointing only works within a certain distance so try moving closer while waving the remote back and forth across your TV.
Aug 31, 2008 | Nintendo Wii Console
Remoye keyless entry
Try spraying a penetrating spray (WD-40 or similar) into key holes on door, and up into latch area. You may have to do it numerous times before things will loosen up. You may need to remove the door panel, to ensure that you've loosened up all the pivot spots on the linkages but I would certainly make sure the linkages going to the locks are all moving freely before I change a power lock motor. Sometimes spraying the lube, and assisting the motor by manually lifting/pushing down button at same time as flipping the switch, will aid in loosening it too.
Jul 06, 2008 | 1999 Dodge Stratus
Codes
Hi wildthingbor
Here is the instruction manual and codes for your remote... took a bit of finding :) A FixYa rating would be great for doing this for ya.. :)
Cheers
regards
robotek
May 08, 2008 | Philips Universal PH301S Remote Control
Akai LCT2715 27 in. LCD Television Logo
64 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
