Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
Problem for Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
Panasonic PT-47wx53, No power, 3 Blinks
By charline on Jul 31, 2007
This morning I turned on my tv and after about 2 minutes it shut itself off. The power led on the front is blinking 3 times. I have tried other power outlets, and I have left it unplugged for 3 hours then plugged it back in. Each time, it attempts to come on but returns to the 3 blink with no picture and sound.
Same Problem
Aug 12, 2008
-   I have a PT-53WX42F. Chassis EP824 Dead With blinking code 5. Any ideas that I may begin looking. Also, IC601 is the Horizontal Out. I will check the Toshiba part 2SK2917 (xref: nte2970) and loose connections. I have visually observed the board but nothing out of the ordinary. I suppose I can resolder the flyback (which looks good) Am i on the right track. -   vger1967
Nov 25, 2007
-   I have the same problem and there is nothing in the manual. There is nothing wrong with my outlets. The solution provided for the initially reported problem was not helpful.-   kphill26
Nov 20, 2007
-   My TV does not turn on and the front light blinks 3 times.-   Guest
Nov 14, 2007
-   TV came on fine this morning, about 10 mins later it went off. My husband turned it back on then after a few minutes the picture went out and the LED light started blinking 3 times. I unplugged and tried another outlet, to no avail. We have had the TV for 3 years in the same exact spot, not sure why we started having the problem. Any other suggestions or should I call a repair company??-   cjowagle
Best Solution
posted on Jan 04, 2008
Very Helpful)
Tim Smith123
Rank: Apprentice
Rating: 95%, 8 votes
Panasonic PT53WX42F with same problem. 3 blinks after power on for a few seconds, no picture or sound. Solution: replaced two convergence ICs (STK392-XXX) located on the large green printed circuit board. ICs are very large and screwed into two large heat sinks and soldered to board. Cost is approximately $6 each. Easy to replace if careful. May be able to access solder joints on bottom of board by removing screen on bottom of cabinet or simply remove 4 screws that anchor plastic holder to cabinet and tilt up. I did not disconnect any inter-board connections. Remove heat sink screws. Desolder using suction bulb or solder sucker. Works great. Finish off with solderwick braid if necessary to clear holes. 40 watt iron is enough do not apply too much heat to damage board lands. Remove IC. Clean heat sink by scraping away white heat sync compound. Apply generous amount of heat sync compound to new IC and coat evenly. Align and insert new IC holes, resolder with thin resin core solder being careful not bridge lands. Refasten to heat sink. Clean board and inspect for good joints and no bridging. Refasten plastic board holder. Carefully clean projection lenses while back is off tv. Power up and it should be fixed. Parts are obtainable on-line. Solder tools and board cleaner are available at Radio Shack or on-line also. I spent $20 on parts and supplies. This is not hard just a bit tedious. You can do it.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 15, 2007
Somewhat Helpful)
troylove11
Rank: Wiz
Rating: 84%, 1286 votes
Check power supply around the small transformers and resolder. Also look for loose connections in powersupply and Check any caps and see if you can see anything out of ordinary.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jun 01, 2008
Very Helpful)
ZyDAS
Rank: Apprentice
Rating: 100%, 1 votes
I also followed Tim Smith's instructions and my TV is now working. The only thing is that as an engineer I realized that the Panasonic TV has a poor way to dissipate the heat which is probably what caused the problem to begin with so I went to Fry's electronics and bought 3 computer cooling fans and adapted them on the back of the TV grid. They are very quiet and they have their own power supply so they do not interfere with the TV operation. In addition next to the same parts that Smith mentioned above I found some resistor that changed from light blue to brownish color this is a sign of overheating. I ordered the resitor directly from Panasonic and replaced them also. So look for some bad resistors.
By the way the service manual cost me $10 and I highly recommend you to get it if you are going to fix it yourself.
Thanks Smith !
Was this helpful?
Yes
No
Solution #4
posted on Mar 29, 2008
Very Helpful)
acris
Rank: Apprentice
Follow Tim Smith's instructions.... I had the same problem and now I have a working TV. The parts with shipping were about $30 and the repair took me about 1.5 hours. Thanks again!
Was this helpful?
Yes
No
Solution #5
posted on Nov 07, 2009
Not Rated)
korey_rowe
Rank: Apprentice
Rating: 0%, 0 votes
What about the 2 blink code, what is that?
Was this helpful?
Yes
No
Solution #6
posted on Mar 20, 2009
Not Rated)
TonyJohnson
Rank: Apprentice
Rating: 0%, 0 votes
Again, Tim is the Man! His instructions worked. I now have picture, however I have a color convergence problem. I read another article about the service menu. I will try this. BTW. I have never soldered a circuit board in my life. I got the TV free on Craig's list. So, for about $20 and a couple of hours of fun tinkering... I have a working HDTV!!!!!
Thanks Tim and FixYa!!
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-47WX53 47 in.
Questions and Unsolved Problems for Panasonic PT-47WX53 47 in.
Do you recommend Panasonic PT-47WX53 47 in. Rear Projection HDTV Television?
Answer
Answer
Panasonic HDTV 2000 purchase. Lost picture and sound suddenly. Turned it on and it continued to... (More)
Answer
our Panasonic PT-47wx53g TV turns on for just a second and then clicks off ... do you have any... (More)
Answer
Panasonic PT-47WX53 53" projection TV TV shut down with 3 blinks.I replaced one resistor and... (More)
Answer
i need remote for old big screen tv. i need to ajust the mirrows.model #trpaa022cim
Answer
I need an upgrade for my Matsushita Wireless Manger. It will only run on XP computers and I need a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic PT-47WX53 47 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
