Question about JVC LT-42X579 42 in. LCD TV
My remote wont change channels
I have a new JVC LCD, a JVC TH-F3 theater system and cable TV. I need to use the cable remote to change the channel and the TV remote to change volume.
Also can regular cable sound come out of the home theater. It has a receiver and dvd player
Thanks
  • JVC Master
  • 5,568 Answers
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Posted on Feb 01, 2009
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
No sound from tv, dvd, cable. Speaker test does work. Sound stopped suddenly when channel was changed.
What does this mean: "when channel was changed"? TV channel?? Would that mean a remote command was issued? How about FM (no external cabling)?
Page 23...
http://www.retrevo.com/support/RCA-RT2280-Home-Theater-Systems-manual/id/402ag600/t/2/
Sep 02, 2011 | RCA RT2280 System
How to get sound to tv from JVC TH-M606 without sub woofer.Also trying to put in progressive mode without remote
  • If I understand your question correctly you want to listen your TV on your Stereo system thru your receiver,JVC TH-M606 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
JVC TH-M606 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
JVC TH-M606 Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • If you want to listen your receiver thru your TV, sorry but it is not a preferable attempt since TV sound system is not a HI-FI quality compare to your nice Receiver..if you really want to do it,try to do the connections given above in reverse..
  • And,best of my knowledge I am afraid you can not put in progressive mode without remote
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Jun 24, 2011 | JVC TH-M606 System
I have a jvc seteup but reciever is broke.is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
http://cgi.ebay.com/JVC-TH-C50-TH-C5-TH-M505-Repair-Service-/360178567658?pt=LH_DefaultDomain_0&hash=item53dc50c9ea
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
http://www.jvc.com
800-252-5722
Jan 12, 2011 | JVC TH-M505 System
My dvd theater system has no color
some times the dvd's change by itself to PAL/NTSC system so you need enter to set up and select the option in system tv NTSC for America users. Make shure conect yellow cable in the yellow conector.
May 25, 2009 | JVC TH-C5 System
I can't seem to be able to get sound through the speakers when i am on cable tv. does anyone know how to fix this problem?
Run a set of phono cables from the tv audio out put to the aux in put on your system and set to prologic.
Hope this helps
CABLE GUY.
May 09, 2009 | JVC TH-M303 System
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
How to get 5.1 sound from plasma tv to home theater system?
You just need to connect an Audio Out port on the back of your TV to an Audio In port on the back of your JVC box. See what connections you have, I'm sure there are lots of options for you such as HDMI or just normal 2-cord audio cables.
Mar 18, 2009 | Sony VAIO VGP-WKB1 Keyboard
JVC LT-42X579 42 in. LCD TV Logo
476 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
