You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
SOURCE: SECURITY CAMERA SYSTEMI
Have you setup a Virtual Server within the D-Link router? This should be on the ADVANCED tab in the D-Links Admin Configuration interface. Upon setup, the router should allow pass through of your request to the network connected device.
You will need the following in this configuration:
Name of device: SSC21WEB (or whatever the name of your device is)
IP Address: 192.168.0.101
Protocol Type: TCP
Public/Private Port: 10000 - 65535
Schedule: Always
Good Luck...
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
SOURCE: Can't log on remotely
did you set up a port to connect through if not you need to set one on the port your DVR needs and forward it. It is called port forwarding.
SOURCE: Would Uniden and Lorex cameras work together? I
I was wondering the same thing. Have you talked to Uniden or Lorex about this?
